Question about Whirlpool Duet GHW9150P Front Load Washer
Settings do not light up and will not start when button is pressed
    President:
  • 2,468 Answers
Your central control unit is dead and needs replacing,its under the top cover on the right side of the outer drum
Posted on Jan 01, 2011
How do I program a curves tech watch, sold by avon. Four options start, reset, mode, light...
There are four buttons - Mode, Light, Start and Reset.
Press the Mode button once and it enters a day setting mode. Press Mode again and it goes into an alarm set mode. Press Mode again and it goes into a time display mode with the seconds flashing. Press reset to toggle through seconds to minutes to hour to day. Press the start button to increase a value. Press Mode again to resume normal functions.
Mar 21, 2015 | Hardware & Accessories
Set time on adidas Adults' Performance Duramo Watch
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Mar 15, 2012 | Adidas Watches
Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Jul 20, 2010 | Casablanca Fan (3232A) Ceiling
I am trying to set a digital watch, there are 4 buttons 1=light 2=mode 3=start&stop 4=lap reset. I can not find the name brand and I bought it at a second hand store for my grandson. The only name I...
mcdevito75here, I'm sue I can help you set this digital watch,----4 buttons, 1=light, this should be just for the light built into the watch, 2=MODE this is the button you press to set the functions, press this button and see everything flashing 3= Start Stop this button should act as set after you press MODE it should also be to start the lap counter and 4= lap reset this should bring the lap counter back to zero or the seconds tick normally.---- press MODE see everything flashing, then press start stop to set functions, hour, minute etc, press MODE after you have set each function, hour, minute, etc. When done with all functions press mode again to bring the watch back to normal operation.
Jun 23, 2010 | Watches
Does anyone have instructions for Nike Imara Fit WR0076?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
May 13, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
How do I set the time for nike imara fit WR0076-002 wrist watch?
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Mar 26, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
I dont know how to set the time
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Nov 11, 2008 | Nike Imara Run WR0075-014 Wrist Watch
Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
I Lost My Small Book on How to set my new Fossil watch Model JR9455-300703
Finally i got it while playing around with my fossil JR9455. . .
Here's the step by step method in setting the time:
1. press and hold light button and press start/split button
(light and start/split are both pressed by this time)
2. you should hear a beep
3. You should notice that the display changed
4. press mode to choose which setting you want to change
5. to change the values, just press start/split button to move up and reset/stop button to move down
6. to finish the setting just press light button again.
This method worked with my watch. I hope this helps. . .
-chickozai-
Jul 05, 2008 | Watches
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Whirlpool Duet GHW9150P Front Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
