Question about Canon Office Equipment & Supplies
Canon 8400F Scanner keeps returning ERROR: release lock switch, detach I/F cable and reconnect. The lock switch IS in the unlocked position, but scanner will not scan.
Have exact same problem on a Canon scanner (N1220U) which is several years old. Suggest you uninstall the driver software and reinstall it. I did and my scanner is scanning fine again.
Posted on Dec 27, 2008
I cannot scan with my scanner: " it says RELEASE THE LOCK SWITCH,DETACH THE USB CABLE
Hi ,
Disconnect your unit from your pc ( usb and power)
Insert your install cd and run the program
Restart your pc
When Windows has settled , connect scanner back to pc .
It should run normaly .
Best regards.
Aug 15, 2014 | Canon CanoScan LiDe110
I just installed my new Canon LiDE 110 scanner. I slid the lock button to the unlock position. When I try to scan, I get the following error: "Release the lock switch, detach USB cable and...
mbrindle is great!!!! Many thanks - I was just about to take it back as I thought the scanner was defective. Would never have thought i had to do that. Thanks!!!
Aug 15, 2011 | Canon CanoScan LiDE100 Flatbed Scanner
I cannot use scanner Lide 25.. because show error : "release the lock switch,detach the I/F cable and reconnect" How solution?
Sounds like the scan head is locked. This is usually done so you can transport the scanner without bouncing the scan head out of alignment. Look under the scanner and you will see it. Make sure it's in the UNLOCKED position. You may need to power the unit off/on to reset it or restart your computer to get a fresh attempt at the scanner.
Mar 05, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
Hello I am having problems saving my documents I am receiving an error message "Release the lock switch,detach usb cable and reconnect.Close the scanner driver .What lock switch is this ?please advice...
-is this a new scanner? is this the first time you are trying to scan?
if you answer yes to any of this questions, please check underneath the scanner, find the latch to release the scanning head.
Dec 16, 2010 | Canon CanoScan D646U Flatbed Scanner
I keep getting a message that says, release the lock switch, detach the I/F cable and reconnect. Scanner driver will be closed
Close the scanner driver and return the scanner to your overlord. Your virgin child will be sent to you immediately.
Mar 17, 2010 | Canon Office Equipment & Supplies
Message received Release the lock switch,detach the usb cable and reconnect. Tried this but it doesn't work. The scanner is not locked!
Uninstalled software, disconnected usb cable. Then reinstalled software and reconnected usb cable.
All up and running!
Nov 23, 2009 | Canon Office Equipment & Supplies
Canoscan lide 20 Error; Release the lock switch, detach the USB cable and reconnect. Scanner driver will be closed.
hi.. there is a lock under the scanner you need to unlock it... lock it to prevent damage while transporting...
Dec 16, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
140 people viewed this question
old marine
old marine
