Question about Sony Xplod (P589) Car Subwoofer
As i play my stereo if i keep it at a lower volum like around 23-25 my sub takes a really long time to heat up and does not get that warm, but soon as you push it passed 25 it starts to heat up so much the speaker is HOT to the touch in the middle and if you get to the magnet it will burn you if you touch it....but my amp pretection light never comes on at anytime while the speaker gets hot and i have let it run for a long time and get really hot.....it seems though even though you smell plastic burning when yolu look at the sub you see no signs of melting or damage of any kind....my xplod is hooked up to a 1000 watt kenwood amp turn at half capacity with a capasiter hooked to it as well......dunno if it matters but even with the amp at half it still gets hot but does it faster when the amp is turned up....the amp bass boost is turned up but i cant see that being a problem...what i want to know is why would the sub get hot and the amp never gets a red light....is my amp just to much for it or is there somthing wrong with the speaker inside
    President:
  • 4,070 Answers
Hi and welcome to FixYa!
Yes the amp may be too powerful for the speakers but I doubt the protect signal. Let's just hope that the protect is working for you may damage the speaker if it ain't. I don't think that the speaker is faulty for there's no distorted sound even on high volume right? It's quite normal for the speaker to heat up but not to the extent that it will burn you.
Please have the amp be checked if everything is normal plus have a good look on the protect for I suspect that it's not working.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Jan 01, 2011
I have a kicker zx350.4 for door speakers and the amp keeps cutting off once the bass hits hard or i have it aloud , once i put the volume down or bass low it comes back to normal and amp doesnt get hot at...
kappas are 2ohm. You are running that amp at 2ohms stereo on front and rear channels. That is a nice amp, but it is a thirsty one. If you have a sub amp as well, then you are not supplying your amps with enough power. drop down to 0 gauge and see if it heats up anymore. Also, try going high pass if you have subs. If you don't have subs. You need to run 4 gauge and make sure you have a great ground.
Oct 31, 2014 | Car Audio & Video
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
My subs are skipping notes and only play low notes decently and only play when the volume is at full blast. The amp wiring is fine and the radio wiring seems alright. No idea why it is
First of all the bass needs to be tuned down on stereo you shouldn't need to turn volume fill blast then you set your amp so your subs sound good hope you have a cross over. Never tune the gain on your amp past 3/4 ether play with you air flow to that some times works I found that if you do this your bass gets louder less risk blow
Mar 02, 2013 | Car Audio & Video
I got Sony Xplod XM-ZR704 700W 4/3/2-Channel Car Stereo Amplifier and 12" sub. it play good for continuous 2 hours but after that starts tripping and goes on off. i checked all wires and connections.
Amp is probably over heating. Make sure the ohm load of speaker is good for that amp. This amp is not really built to handle a bridged 2 ohm load. Make sure ground wire is clean and tight to the body chassis.
May 18, 2012 | Sony Xplod XM-ZR704 700W 4/3/2-Channel Car...
I have a boat and installed a jvc stereo and a kenwood 1000w amp to power my 10inxh jbl sub running off the stereo 4 6by 9 3 ways and 2 twitters volum cut out at 33 i do have the amp wired direct to the...
Sounds like you have a lot of equipment on your boat, cool. But you need to think about the load you are putting on the battery. If you don't have a way to charge the battery back up, you just keep getting the power lower and lower the more you play. Also, with that much draw, it probably doesn't take long before you experience this. Unless your engine is internal and has an alternator to it to recharge the electrical system. This will keep happening. A couple of choices you can make. Either downgrade your system to something that has less draw (definitely ditch the 1000w amp and sub), or you can put more batteries in your boat. Kinetik makes great audio batteries, but regardless of how many you put in your boat, there has to be a way to recharge them. You will probably need to recharge the battery after every use. Hope this helps
Aug 28, 2011 | Car Audio & Video
When volume turned up subs pop then immediatly produce no sound
u might have to turned your amp so u can play both subs your amp might be to small to run both subs at the same time an u gotta play around with the settings on your cd player so when u blasted your subs it has that nice bass to it not that poping sound.
Apr 04, 2009 | Jl Audio 13W7 Car Subwoofer
Amplifier Issues
HERE is the manual for your amplifier.
It is listed as being 4ohm STEREO stable Bridged.
Meaning the lowest impedence possible on (2) bridged channels is 4 ohms.
If you have a Dual Voicecoil Subwoofer, chances are - it is wired in parallel - resulting in a 2 ohm load.
This low resistance causes rapid heat buildup, and is causing your amplifier to go into protect mode.
There are many reasons the amplifier is doing it NOW as opposed to the prior vehicle...
If you alternator is not giving your amplifier 14V, it must work harder to produce the same amount of power. WORK = HEAT!
If the head unit is not the same, the signal voltage also has an effect. If the voltage is lower, the amplifier has to work harder to keep up at the same "volume" setting.
In any case, you are over-driving the amplifier, and it is shutting down with its thermal protection circuit.
Either lower the gain on the amplifier, or purchas a mono channel amplifier made to drive subwoofers.
Your Subwoofer is craving power, and you're giving it 60W !!
Thank you for using FiXyA - A FiXyA rating is appreciated.
If you have more questions or need clarification - let me know!
Jan 21, 2009 | JVC AM FM CD DET FACE CAR STEREO
Turns off if sound level is increased
there is a protection circuit kicking in.
First thing to check.....Verifiy that all speaker lines are in correct polarity.
+ and gold or writing/stripe on cable.
Check this all the way around and if the sub is a line in sub,, check that also.
You really should just unplug them all and start one by one.
If you cannot get to the wires or its too hard to access,
hold your hand 1/8 of an inch from the woofers. they should be kicking out, not pulling in.
Could also be a blown woofer somewhere in the system.
Hope that helps!
Charles
Jan 09, 2009 | Onkyo TX-SR606 Receiver
Kicker kx600.1 class D mono amp
This question really can't be answered accurately online for a few reasons.. we don't know if you have a ported or sealed box, we also don't know what kind of box you have, wether it's a 4th order, 6th order...blah blah blah. We also don't know what the box has been tuned to (if it's ported). unfortunately, you'll have to play around with it yourself or get someone to physically see your set up. But here are some tips to help you tune your set up.
1st set up the frequency( or crossover). this basically tells you sub the range it should run in. alot of people don't set up their crossovers properly and the sub is reproducing frequency's the mids are producing so some notes are far louder than they should, which makes for unbalanced audio. when you get that sorted out move onto the gain. (keep in mind, that if you've only installed a sub and have stock speakers or are running upgraded speakers off the head unit and not an amp the frequency is going to be harder to control since you can't control the other speakers.) next the gain, the gain is really just volume. Play a song with alot of bass and set the sub at a volume that pounds, but not to the point where your other speakers get drowned out and there you go, you should have a pretty good sounding setup. If this is the first time you're tuning it may take some time, but please do this with your car running, far to often i hear people killing their batteries as they don't realize that amps really do **** alot of power.
If you purchased the subs and box separately the box usually tells you what it's tuned to (if ported) and you can use that to guess where to set your frequency.
Oct 30, 2008 | Kicker KX600.1 Car Audio Amplifier
Sony Xplod (P589) Car Subwoofer Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
