Question about Philips Magnavox DVD/VCR Dual Player
The DVD drawer will not open; there is a DVD stuck in the player
  • Philips Master
  • 6,771 Answers
The unit will need to be disassembled, in some cases you might find a pin hole in front of the tray. Take a fine screwdriver or a needle and push in until you hear a click, the door should pop open. If that option in not available, remove the top lid of the machine, go to the dvd sector and carefully remove the dvd top, that should expose the disc for removal.
Posted on Jan 01, 2011
    Problem Solver:
  • 6 Answers
I found I could use the same belt - if I used the right lubrication material - in the right spots - gear shafts, or where it binds - it can bind in places - the motor is protected from stress when gears and movement is restricted - binding.
Therefore moves inward or outward or shuts down. Once its not binding or restricted it therefore becomes a belt missing - some shafts are plastic and can break - belt to tight - the motor is controlled by a sensor therefore there must be free enough movement to prevent belt or motor damage therefore has sensor to protect motor.
Posted on Nov 28, 2014
5 Suggested Answers
  • 8457 Answers
SOURCE: DVD stuck in player, drawer won't open, any
Unplug,replug about an hour later should be back to normal reset to factory setting.It should open and close ur DVD tray again,if ur motor is not burn or dead.
Posted on Dec 10, 2009
  • 70 Answers
SOURCE: DVD stuck in player SONY RDR-VX 515
Take the lid off by taking the 2 to 4 screws out of the sides of the unit to get the disc out.
Posted on Feb 19, 2008
  • 979 Answers
SOURCE: DVD recorder DMR-E55
Describe "self check" mode?...accordianman
Posted on Nov 26, 2007
  • 151 Answers
SOURCE: dvd tray will not open
If you press the open key and it say open on the display then yu have a cut belt / blowm loading motor or power preoblem insdie the set. If it does not say open/close on the display then you could have a faultt button or processor.
Posted on May 12, 2009
Dvd tray wont open
Hello
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
6. You might need to see a technician.
GOODLUCK
Jan 27, 2011 | Amphion Mediaworks S99 DVD Player
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Nov 23, 2010 | Denon DVM-1805 DVD Player
The DVD door will not open when the button is pressed
Please check the bellow instructions:-
Turn off your DVD player. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Please get back to us if you have any further query or else accept the solution.
Nov 01, 2010 | Panasonic NVVHD1BS DVD Player / VCR Combo
Stuck dvd drawer
Unplug the player. look on the back and bottem for a small hole. stick a straight paperclip in the hole, and the drawer should open part way.
Jun 28, 2010 | Mitsubishi DD-8030 DVD Player
I have a DVD that is stuck in my TIVO. The screen
Take the DVD player aparts,take out DVD disc out of the drawer,check the open/close drawer button again.Same result indication on the screen say is open infact it close.The motor the help open and the dvd drawer it dead.Need the motor replaced.
Jun 26, 2010 | Humax T800 TiVo 80-Hours Video Recorder
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
The DVD drawer will not open on the model TT 320
Hi
Thanks for using FixYa. Please locate the DVD player’s manual eject button which is a small hole located underneath the DVD drawer. Now insert a stiff wire like a paperclip or safety pin into the hole and push gently to open the drawer. Now pull the drawer gently to open it. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling then you need to remove the label. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player and you need to have it serviced.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | TruTech TT320
DVD drawer will not open on Zenith ZHX-313....help???
hi friend,
Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. If this is the case you should have it serviced or perhaps it is time for a new one.
I hope this helps.
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Zenith ZHX-313 System
Philips Magnavox DVD/VCR Dual Player Logo
699 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
