Question about Aprilaire 600 Humidifier
Aprilaire 600 was leaking water from bottom of unit...subsequently filter pad replaced and all parts cleaned of residue; drain tube cleaned and is draining...The problem is that water is still dripping excessively from the bottom of the unit. Please advise. Thank you.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you must have a defective water inlet valve, and its letting water in, just a little.. it maybe dirt in the valve, clogging it.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
My Aprilaire 600 is dripping from the front toward the bottom... Can I fix it myself or do I need my maintenance guy?
Hello, check to make sure that the drain line is not blocked, this could cause the water to back up in the humidifier and leak, also make sure the water panel is clean and free of any mineral deposits.
Feb 09, 2011 | Aprilaire 600 Humidifier
2 months into the heating season I noticed a large puddle around my heater. the Aprilaire 600 unit was leaking. The distrution tray had a red substance around the water holes. Also the overflow drain line...
Mold can really cause problems with humidifiers-
They do need to be serviced, cleaned up, and something like weak bleach used to kill mold spores, -- get it all tidy and clean!
Were you able to clean out the drain line?-- and is it draining now?
And is the float valve shutting off the water flow, before it reaches the overflow drain pipe?
Another concern would be the soaking pad-- Has it been changed recently?
Tell us more--
Mack B
Jan 06, 2011 | Aprilaire 600 Humidifier
Should water be continualing running through the drain tube?
Water will flow over the filter pad as long as the unit is calling for humidity. once the unit is satisfied the solenoid valve should stop the water flow. if the water continues to flow with out call then solenoid valve has failed open. hope this helps.suppling an owners manual in case you need one.
http://www.aprilaire.com/themes/aa/en/manuals/AA-Humidifier-Owners.pdf
Dec 21, 2010 | Aprilaire 600 Humidifier
Water drips from unit
lift the frontup2 inches should drain out back if not blocked
thumbs up
Aug 17, 2009 | Aprilaire 600 Humidifier
The unit leaks water on the floor
you need to replace the pad every season. if you are using a generic pad maybe more often. it also must be level and the drain coming off bottom clear. i suggest getting pads from aprilaire.com . not the generic from hardware store. also if its got a black feed tube going from the solinoid valve to the top of the humidifier pad you may want to replace that aswell, they have been known to crack the new ones are grey.
Aug 10, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 leaks water from bottom of case
Install new water panels yearly. On the new panel make sure that the painted dot on the edge of the panel is on the top when you install it.
Always clean the distribution tray and the frame. Make sure the notch on the edge of the distribution tray faces away from the furnace. Make sure the humidifier was installed level. Keep the drain tube opening clear. Insure there is no blockages in the drain tube.
Good luck
HVAC Teacher
Feb 10, 2009 | Aprilaire 700 Humidifier
Water runs out of the bottom of the unit
Check your plastic water orifice. It is in the hose fitting connected to the outlet tube of the water solenoid. It should be a blue one. Mine was completely eaten through, allowing full water flow, and thus overflowing the distribution tray. I replaced mine yesterday and no more water drips. May as well reflace the filter on the inlet tube of the solenoid at the same time. I used a piece of very stiff, but thin, wire formed into a small hook to remove both old parts. Replacements are readily available from multiple sources on line.
Feb 05, 2009 | Aprilaire 700 Humidifier
Water seeping through drain spud area of Aprilaire 600 model.
Clean it and dry it thoughly. Apply a small amount of 100 % silcone caulking with you finger. Seal it on both sides. Allow it to dry thoughly before it gets wet or it will leak.
Jan 22, 2009 | Aprilaire 600 Humidifier
Water Leak
there is a nozzel at the end a black tube at the top of the hummidifier that has come off or the tube is cracked
Dec 24, 2008 | Aprilaire 550 Humidifier
Installed a 600 system.
turn the water main back on to the house.
Dec 09, 2007 | Aprilaire 600 Humidifier
Aprilaire 600 Humidifier Logo
419 people viewed this question
Top Aprilaire Humidifiers Experts
paulcarew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
