Question about Nokia 2720 Cell Phone
I am unable to text. The letters I type in are not coming up correctly. There is a line under the letters and the same letters keep repeating themselves. I suspect I did something goofy with the # key or the 0 key. I don't know for sure. Hope you can help.
4 Suggested Answers
  • 55 Answers
SOURCE: When trying to text incorrect letters appear
There should be an option somewhere when you are in the message menu on how to switch from the text mode that tries to finish your words for you to the text mode where you have to push the button however many times to get the the single letter you want. Although if you are in the auto finish mode you can simply ignore what it's suggesting and continue spelling out the word yourself if you want. example: hit 9 6 8 one time each to spell the word "you"..buy if your trying to be able to short hand text like "thk u" your gonna have to look around in your text mode settings.
Posted on Jan 02, 2009
  • 7 Answers
SOURCE: When typing a text, I can't pick the letters or numbers I want.
that means your messaging font is set to type the word for you. find "options" then look for soomething that ays "abc" your phone is set to type in "t9"
Posted on Apr 09, 2009
  • 78 Answers
SOURCE: some of the keys on my E71 keyboard are not typing
CHANGE YOUR KEYPAD OR KEYPAD BLADE
Posted on Oct 06, 2009
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
Wanting to turn off predictive text - to allow older user to type individual letters and so words
when texting push the hash ( # ) key ounce or twice untill the pencil at the top of the right hand screen has no line under it
good luck
Dec 02, 2010 | T-Mobile Cell Phones
Repeating letter on viewed webpages and while typing
install powerful antivirus, if not work change the keyboard
Nov 26, 2009 | HP Pavillion ZV6000 Notebook
Every fifth line has a white streak through the
I would try using something like rubber renew on the pickup rollers and make sure that the paper is being fed correctly. If this is happening then start looking at the ink.
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Some printers will let you re-run a cleaning utility from their system menu or the computer printer properties. Keep in mind too that some printers will not print correctly, even with full ink, if the exact type of ink it expects you to have is not installed. If all else fails change out the ink, but double check that the ink is correct against the manual or written instructions inside the printer. Not every cartridge that fits the printer necessarily is the right type and using the wrong ink can cause unexpected results.
Nov 08, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
When I start to type a words automatic words come up
I assume you mean when you are writing a text that this happens?
This is predictive text (t9),where the phone automatically tries to predict the word which it thinks you intend to type,
It has its advantages in that it can make typing a text faster but it does take a while to get used to and some people just prefer to text by the method they are already used to,
You can disable the predictive text if you wish and use normal text for your letter input,the option will be on your phone in the settings,if you are unable to locate the option reply back with your make/model of handset and I will tell you how to disable it
Sep 07, 2009 | Lands Phones
Typing & viewing text messages on Samsung SGH-A411.
Dear
Turn of dictionary function, in that function ur phone directly suggest a word ageinst letters u type ex. if u type h then it suggest hi,hello ets
I m unable to tell how u can turn it off as u have not mentioned ur phone's name & model
Some Brands in which i know how to turn off its
Nokia - Press # key to change wordsn in left corner turns to abc from abc_ or just go to option & turn off dictionary
Sony - In message composing go to menu & turn of T9 Dictionary
Thanks
Mar 16, 2009 | Cell Phones
HP ZD7260US 17" laptop has three problems.
you need to replace the key board funny this will probly fix you vol text problem too it sounds like the vol key may be stuck you should be able to buy a keyboard on ebay for less then $30 and make your laptop work correctly
Feb 20, 2009 | HP Computers & Internet
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Text messages
Hi, Hi-Tech people! I got a Motorola RAZR V3, my problem starts when everytime I press the keys to type a message...it HANGS. Once it HANGS, I can't type anymore and continue the message I suppose to write. It wont move no more. It just STUCK-UP right there on the last letter I'd pressed. I have to take-off the battery at the back to re-start the unit again. Then, start typing again...same thing happens. It just HANG by itself and I can't press other keys no more.
Any HELP?
MannyQ
Jan 21, 2008 | Cell Phones
Nokia 2720 Cell Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
