Question about BenQ MP610 Multimedia Projector
Lamp unit 6k.01213.001 - BenQ MP610 Multimedia Projector
What is code 1ce t3
The th3 sensor on the back of the generation 1 ice maker in your fresh food section is out. Check the resistance of the sensor and it should be between 6k - 80k ohms. If the sensor is good the ice maker control board on the back of the unit is faulting.
Feb 19, 2015 | Frigidaire Refrigerators
Christie ds+6k, buttons getting power, LED display has no power, and will not powering on
Button Panel lights up with power cable in ,means the power supply is ok
pls check the mainboard
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Jan 11, 2014 | Christie DS 6K OEM Projector Lamp
Model # PU30EK Serial # 32E00561B how many ton unit is this ?
I am guessing 2.5 tons. One ton = 12k btu's one half ton is 6k btu's. 12k plus 12 k plus 6k = 30 PU30EK = 2.5 tons
Mar 31, 2011 | Heating & Cooling
What is 6k maintenance?
6K-Service Preventive Maintenance
  • 15 Point Check
  • Change Engine Oil
  • Replace Oil Filter
  • Top Off Fluid Levels
  • Lube Chassis
  • Adjust Tire Pressure
  • Check Spare if accessable
  • Rotate Tires *
Feb 01, 2011 | 2007 Aprilia Sportcity 250
Every so often ithe screen just goes blank and you can't change channels or input devices when it does this. There are no blinking lights or no codes being shown, the green power indicator light stays...
It sounds lamp is reaching to end of its working life and causing that problem due to its weak result.
Replace lamp in tv to solve this issue. Lamp replacement procedure is easy and written in user manual of tv, please buy Sony original lamp for good picture in tv.
Thanks.
Feb 01, 2011 | Sony KDF-E502000 50" HDTV
I'm having code 16 before start up, sometimes the engine light comes on while running.
a code 15 and 16 is throttle position sensor short circut or stuck open. it will failsafe to the the open position. disconnect connector from the throttle body and ohm out(on the sensor) the blue(pos)/blue-white(neg)( should be 4-6k max) and the yellow(pos)/black-blue(neg) should be 6k max ohm. make sure when you are twisting the throttle that the ohms increase and decrease smoothly and are not jerky. if they are higher, replace sensor. also check that the yellow/black-blue wires in the connector wire side only put out between 0.63 and0.73 volts. if its more or less you will need a new fuel control unit.
Jun 13, 2010 | 2002 Yamaha YZF-R1
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
Runs fine until bike warms up then misses
your cdi unit is suffering a from power surge try to check the output power if it is stable.
Apr 16, 2009 | 1995 Yamaha FZX 250 Zeal
BenQ MP610 Multimedia Projector Logo
279 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
