Question about Refrigerators
Model FF631 continues to frost up, thus requiring manual defrost by removing the ice, any ideas?
  • 1,772 Answers
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Testimonial: "thanks good info"
My Avanti refrigerator Model # Ra7316Pst only freezes when you put the Thermostat at Max. Then the contents in the ref. all freezes. Any Ideas ? Ray
Fridge/freezer freezing up- and no fan or air circulation:
first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice.
AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
https://www.youtube.com/watch?v=6SJN8oaA2XE
https://www.youtube.com/watch?v=buX9KcZo2c0
https://www.youtube.com/watch?v=gVXT7pZyk_o
https://www.youtube.com/watch?v=53ZFeiWgtuk
God is so good: so this is why I give free advice so please thank him not me.
Refrigerator Repair Frosting up in freezer not cooling Admiral RSCA207AAM Freezer Frost Repair Freezer Frost Repair Kenmore Whirlpool refrigerator frost build up in freezer not cooling...
Feb 06, 2017 | Avanti Refrigerators
Frost build up in fridge and freezer only maintaining -5 temp??
Refrigerator Repair Frosting up in freezer not cooling Admiral RSCA207AAM Freezer Frost Repair Kenmore Whirlpool refrigerator frost build up in freezer not cooling...
Mar 17, 2016 | Frost Refrigerators
Why do the evaporator coil frost up across the back of the coils and not on front next to door about 4 inches?
Kenmore Whirlpool refrigerator frost build up in freezer not cooling... Freezer Frost Repair Refrigerator Repair Frosting up in freezer not cooling Admiral RSCA207AAM
Mar 08, 2016 | Frost Refrigerators
Ge monogram beverage center has ice build up and not cooling
Anytime there is ice buildup it will not cool. Was the door left open? If so that would cause ice buildup. If it wasn't left open and it is a frost free model you have a problem with the defrost circuit. Unplug it and Manually defrost it with items removed by using a hairdryer and towels to absorb water from defrosting Afterwards it will cool again .If the defrost circuit needs service the unit will continue to frost up. Usually in frost free models there is a heater that goes bad.
Aug 01, 2014 | GE ZDBC240NBS Beverage Cooler
Kenmore Freezer 106.727581: The freezer ices up and the temp goes up to 34 degrees. If I manually defrost it, it goes to 5 below zero in about 6 hours. How can I determine which of the below need to be...
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Aug 21, 2011 | Kenmore Freezers
I have a whirlpool refrigerator model #GT15HTYMQ81
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The defrost timer The defrost thermostat (also called the bi-metal switch)
Aug 21, 2011 | Whirlpool GT1SHTXM Top Freezer...
Bottom of ice maker is frosted up & leads to food getting frost
Sounds like your freezer is pulling outside air into the freezer from the dispenser door or around the door seals. This could be a defrost problem beginning as this is moisture remaining inside the freezer compartment and not being taken out during defrost. So it may be a good idea to look into the back of the freezer and see if there is frost forming also on the rear wall. If yes you will need to manually defrost by unplugging the refrigerator and removing the rear panel in the back of freezer to expose the evaporator coil. If frozen over I want you to defrost with a hair dryer until we can have a look at the defrost heater below these coils. The heater in your model PSS26MRSS has glass around the heating elements and will be easy to see if the element is burned out. If burned out the defrost heater part number WR51X10055 and the defrost thermostat part number WR50X10068 should be replaced. Let me know if you are ready to begin or if this is helpful. If by chance these 2 parts look OK then we will need to look over the main control board for burn marks or signs of heat damage. I'll be here if you need me Thanks, Sea Breeze
Aug 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Need photo of Defrost Switch or Sensor
Unit needs to be cold when you test. it closes at around 20 or 30 degrees F and opens around 55 deg F
Jul 02, 2009 | Viking Professional VCBB363SS Stainless...
No self defrosting. Ice builds up clogging the vents. Freezer gets very cold, fridge not cold enough... Kitchenaid model KSRG25FKSS15
Hi. Are you having frost build up or is the drain icing up?
If it is frost, remove the rear panel inside the freezer and check the defrost heater and the bi-metal switch for continuity. If either switch shows no continuity, replace that switch. The bi-metal switch which is located on the top of the evaporator coil, needs to be tested while it is still cold.
If eithe part shows good, the you will need to replace the defrost timer.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | Refrigerators
Whirlpool Freezer Model #EV150NXENOO
This one sounds like the defrost timer is not working and you are not getting a defrost cycle every 6-8 hours (or when needed). Another issue could be that air (moisture) is getting in from a leaky door seal, etc. and causing the freeze up. If you have a sealed system problem where the cooling coils are not uniformly frosted up then the defrost thermostat will not "know" there is an ice condition and therefore not go into defrost mode (same issue if the defrost t-stat is bad). After you have ALL the ice out of the unit it would be a good idea to take the interior rear cover off so you can view the coils. Start the freezer back up and watch over the next 1/2 hour or so to see that the entire coil is frosting up uniformly. If it isn't you may have a plugged system, a leak causing low refrigerant, etc. If over time the coils look uniformly frosted up you may have a defective defrost heating element itself (no heat, no defrost sort of thing). The defrost elements can be checked with a multimeter for continuity if you know how to do that sort of thing. It's hard to know a person's ability by these forums or if they can tackle certain test procedures.
Nov 12, 2006 | Whirlpool 19.6 cu. ft. Upright Freezer...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
