Question about Amana ARS266ZBS Side by Side Refrigerator
Ice maker making noise clicking sound????// - Amana ARS266ZBS Side by Side Refrigerator
Bgillespie
  • 89 Answers
SOURCE: Ice maker
Replace ice maker!
Posted on Dec 16, 2007
SOURCE: Kenmore Coldspot Ice maker is not working on our side by side refrigerator
This is a Whirlpool made Kenmore there fore from what your telling me about your ice maker I'm pretty sure it's the ice maker motor module. If you take the cover off the ice maker you will see a large white gear in the center is a little two headed pin to keep the gear in place, if the pin is broke or twisted in any way that is your problem and you will need a new icemaker motor module. Check first and let me know then I will tell you how to install it, it's VERY easy and only takes 15mins. Hit me up when you find out hope I helped.
Posted on Jan 24, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Amana French Door Bottom Freezer Refrigerator making noise but not making ice
The noise you hear is the ice maker trying to make ice without a water supply. Check the line to make sure you didn't knock anything loose or kink it when changing the filter, and check for a plugged line. It could be that there is ice build up in the line, a defrost will cure that.
Posted on Jul 08, 2008
bobicehouse
  • 1524 Answers
SOURCE: Automatic Ice Maker making grinding noise and will not release ice
The mold heater on the bottom of the ice maker is shot, that is why the cubes will not release. The grinding is the sweep arm trying to push the frozen cubes out.
Posted on May 06, 2009
  • 14 Answers
SOURCE: My ice maker can't make ice.
Sounds like the water may be off to your unit or the solenoid is not opening to feed the water to the ice maker.
Posted on May 16, 2009
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Ge refrigerator gts22wcm ice
Inspect the ice maker itself, sounds like either you have a jammed cube or your ice maker is not turning on heater to eject ice cubes from mold. If heater is the failure - replace ice maker. If unit is jammed, clear the ice maker mold and allow to cycle to see if damage was done to gear or ice production is restored.
Good Luck
Oct 23, 2013 | Thermador T36IT71NNP (196 cu ft) Bottom...
Subzero 690 ss icemaker making a clicking sound why
If the noise is coming from the ice maker head itself. Then it sounds like the gear is slipping. They are plastic and it is very common for them to crack or break. Most ice makers are the same. Click Here to see a post on a Whirlpool ice maker with a broken gear.
Good Luck From David at refrigerator repair.
Apr 04, 2013 | Refrigerators
Ice maker is not making ice. Water dispenser is working. It sounds like it is trying to make ice (clicking noise).
the first thing to check is the fill tube and make sure there is no frozen water blocking the tube.if there is no water blocking the tube then make sure you water fill valve is good you might have to replace the ice maker itself.
Feb 24, 2010 | Frigidaire PLHS237ZD Stainless Steel Side...
My ice maker is making a loud noise
MOST HAVE A PLUG OUT OF THE I/MAKER,JUST BEHIND THE I/MAKER,JUST UNPLUG IT THERE..FRED
Feb 14, 2010 | Refrigerators
Ice maker not turned on or hooked to water line
it my be not the icemaker check fan or you can remove icemaker
Feb 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana ARS266ZBS Side by Side Refrigerator Logo
308 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
