Question about Compaq 449901-001 - HP Presario V6500 V6600 V6700 V6800 Series Full-Featured (FF) Laptop Motherboard
Hello sir, The problem with my laptop compaq presario v6500 is that it works on battery but it does not work on AC power while my charger is alright. neither its battery is getting charged. i took to a service center and had diagnostics test and reported that it had a problem with its dc connector in its motherboard...and they suggested that they can only replace the whole motherboard as they dont provide the services of repairing such problems..can you please suggest me an alternate solution to the problem??? i would be very thankful to you if you do so...
    Sergeant:
  • 223 Answers
Hi karun, i think your hardware eng may lie to you,its not necessary to change hole motherboard for this problem , if you have problem in your motherboard mean you cannot ON your laptop itself , just try to take your laptop to some-other hardware expert to do this process, or may be he didn't get spare of DC jack for your laptop.
But i am sure if you change your DC jack is more enauf for this problem, i have search how to do DC jack process in online, i got one site too. just check it and try to show it to your Hardware eng.If possible ask about you can able to get DC jack spare in your area , some hardware eng can help you by putting DC jack of old laptop of same model. Just don't change your motherboard until you have try all this process.
just copy and paste the link in your browser : http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Good luck ! if you think your problem solved don't forget to rate
Posted on Jan 01, 2011
My compaq presarion won't start up and the led in the charger hole won't light on
Try removing the battery and only using AC power. If the power
LED on the power brick does not come on then replace the power supply. If it works with just AC then replace the battery. If it still doesn't work, warranty replace the computer.
Mar 28, 2014 | Compaq HP Presario CQ61-314TU Laptop...
Charge battery
Battery dead? Replace battery. Is the laptop working on AC? Try another cord/charger with the EXACT same power specs. Has the AC jack been damaged?
Jan 26, 2013 | HP Compaq Presario CQ70-120US Laptop
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Charger lights up on side of laptop but no life in keyboard screen etc
I've suspect that you haven't an output voltage on your charger feeding to your laptop. You can to confirm it by testing with a multitester. The very common caused is the internal open wire in the output plug due to frequent bending and pulling.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
Feb 10, 2011 | Compaq Presario V6500 Series Laptop...
HI I have a hp/compaq presario 6500 v6500 product no: GT406EA Serial no: CNF7372MTN Turn on, power to the pc. battery light ok, can here fan starting, but no post double beep & absolutely...
2 beeps usually means a memory error, however, you should get an error message. Try removing and re-inserting the ram modules one at a time
I assume you have tried to see if the ac adaptor is putting out the correct voltage?
Jan 10, 2011 | Compaq Presario V6500 Series Laptop AC...
Itermttit ac and battery power on laptop compaq presario r3000. ac sees to work fine and then goes to battery (battery discharges in less than 30 miutes) - mp
your are probably experiencing a short in your ac cable, the next time it happens wiggle the cable, if the ac pops up in the task bar stop using the charger and buy a replacement.
PS check the slot where the adapter plugs in the back of the laptop to see if its loose, if it is take to the repair shop.
compaq are known for tis problem.
May 26, 2008 | Compaq Computers & Internet
Batery light blinking
try rundown the battery 3 times if still not holding charge your battery is faulty you have to replace it.
regards
Richard
Jan 28, 2008 | HP Compaq Presario V2000 Notebook
AC charger for a presario v2000
use ebay, same thing but cheaper in prices... i got my presario v2000 ac power charger for 24.50 with shipping and handling.... took 3 days and it arrived unless u want to do overnight shipping which is like an extra 12 bucks which is good too... WELL WORTH IT EBAY IS THE PLACE... i think his name is "honestworks" or something like that buy it from him he has a one year warranty if any defects occur...
Oct 18, 2007 | HP Compaq Presario V2000 Notebook
Compaq 449901-001 - HP  Presario V6500 V6600 V6700 V6800 Series Full-Featured (FF) Laptop Motherboard Logo
192 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
