Hi, We just moved into
Hi, We just moved into a new condo, and inherited a Maytag Neptune Stacked Washer/Dryer; the washer model is MHW2000. The washer (and dryer) work well, but once the washing cycle ends, some water remains outside the laundry bucket, caught in a pocket in the gasket between the bucket and the door. It just sits there, never quite drains, and thus, starts to smell. Is there any way of fully draining the water after the cycle? Thanks. Joe ****
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
On the bottom of the rubber seal, there is a drain hole. Check to see if it is clogged and clear it out if it has an obstruction.
Posted on Jan 01, 2011
I maytag neptune stacked washer and dryer model # mle2000ayw just recently the dryer started to act up it doesnt wanna dry the cloths all the way so we have to put it over again !! sometimes 3x ...
hi gar.... sounds like your dryer vent pipe or outdoor vent is partially clogged with debris. thoroughly clean it out and it will work great once again. Joe
Jun 17, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Dryer
Hi thanks for the question. the top of the dryer comes off. revealing the screws that hold the baffles in place . re- install the baffle, and the top. thanks the appliance doc.
Oct 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag neptune washer: will not start
plug a light into the washer outlet to check for elec current at this point before anything else.
Aug 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Stacked Maytag Neptune - Accessing Inertial imb/Upper tub disp Switches
The switches you are referring to are set-reset. These rarely have a fault. Normally the machine control board is the faulty component. How did you determine that these switches are faulty ?
The safest way to access the upper portion of the washer is to remove the dryer. Another method is to remove the "complete" washer front and the control panel. This will give you access to the top of the washer tub.
Jan 04, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag stacked washer/dryer
CHECK THE DOOR SWITCH TO SEE IF THE WIRE ARE CONNECT CORRECTLY. ON THE SWITCH THE WIRE FROM THE BULB SHOULD GO TO N/O IF ALL WIRES ARE CORRECT .THEN YOU NEED TO REPLACE THE DOOR SWITCH
Jan 03, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
