Question about NAD T760
NAD T760 Speakers start to distort after about 5 minutes when playing a CD OR DVD. Also sometimes, no audio ---just distorted sound coming from speakers.
4 Suggested Answers
  • 189 Answers
SOURCE: buzzing emitted by vsx-409
Could be the result of having DTS compatible equipment connected through the analog inputs on the VSX-409D. Noise and distortion will result as essentially the DTS signal is being played back undecoded. If this is the case you'll have to connect your LD or CD player through the digital connections (coax or optical) and set 'Signal Select' (button on front) to 'Digital'.
Posted on Jan 07, 2008
ziraffa
  • 827 Answers
SOURCE: NAD T760 remote control
You could buy a universal remote control and try the following NAD audio remote codes to program it with:
NAD
575 773 975
I read somewhere else that the 'Supplied Code for NAD receivers' was 033, but cannot confirm this. Try the first 3 first.
Universal remotes tend to be pretty cheap, certainly cheaper than buying one from NAD.
Good Luck
Chris (ziraffa)
Posted on Dec 20, 2008
dunnbiker
  • 8546 Answers
SOURCE: Center Speaker Audio Very Distorted
Love your screen name.
You didn't say what, if anything, preceded the appearance of the problem. There might be a clue.
Can you describe the distortion? Is it excessively bassy? If so, is it happening on all sources?
I'm assuming this is a modern digital receiver that is capable of many soundfield simulations as well as native Dolby Digital, DTS, multi-channel. If so we can use a stereo source and through simulation redirect some of it to the center speaker.
Using one of your receiver's many multi-channel simulation modes, put in a CD or tune an FM station and use it to diagnose the problem during later steps.
If it's only a single source and that source uses individual analog channel RCA cables, swap in another one or temporarily move the Center Channel feed to one of the other channels to see if it's before the receiver (in the source).or inside the receiver.
For multiple sources:
Is your Center speaker defined properly as Large or Small in the receiver's setup menu?The size refers mostly to the bass-handling capacities of all your speakers rather than their physical size. Speakers designated as 'Small' will not be sent much in the way of bass because they can't handle it well. The LFE/subwoofer channel(s) will get all the bass that was intended for them instead.
If you have a Small speaker improperly defined as Large it may be getting bass that it can't handle and that might sound like distortion. Having a Large speaker defiend as Small would result in less bass than expected but otherwise 'clean' sound.
Check the speaker setup in the menu for excessive volume level relative to the others. There is usually a calibration procedure the receiver will use to help you adjust the subjective voume of each speaker using white noise or tones.
Hope this helps.
Posted on Apr 02, 2009
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
My panasonic SA-PM193 died after 3 hours of playing music after i added a 4 inch subwoofer and 2 small speakers
... whatever that tells us.
If you severely modified the load to the amp by running more speakers than it's designed to drive and/or at a lower impedence, well, are you surprised?
It only pushes around 25 watts/channel AT TEN PERCENT DISTORTION through a carefully and unrealistically limited bandwidth specification.
http://audio.manualsonline.com/manuals/mfg/panasonic/sc-pm193_1.html?idRes=699618
Running 'clean' (under, say, 1% distortion throughout th 20-20000hz range) it probably only pushes 10 watts/channel. Once an amp is taxed beyond it's clean abilities it will start to distort, badly, and distortion will kill speakers and maybe the amp itself.
Sep 23, 2011 | Panasonic SC-PM193 Micro SystemMicro Audio...
I have a dell dimension 3000 desktop and the sound from the cd/dvd rom drive is distorted or choppy when i play a dvd rom or a cd
hi go to start, settings, control panel, click on sound and audio devices. on the volume tab locate properties and click on it. now another box will appear look for cd volume and adujst it whist playing a cd until the sound is less distorted. please rate me if this solves you problem.
Feb 23, 2010 | Dell Dimension 3000 PC Desktop
Surround sound speakers distort when playing blue ray dvd.
what you have to do is turn off your system then turn it on until you get 2 beeps. then go through the on screen instr.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Distorted audio from pc dvd-rom playback
Try getting new speakers before you throw it out the window....lol
Mar 11, 2009 | Dell Dimension 4600 PC Desktop
Sony SLV-D300P Video Distortion
Have you tried pressing the progressive button on the front panel of the player?
Mar 27, 2008 | Sony SLV-D300P DVD Player/VCR
Distorted audio
I think the volume increasing or decreasing of you woffer box has been got damaged please change your button as quickly as possible...
Thank you..
Jan 02, 2008 | M-Audio DX4 Active Studio Monitors (Pair)...
Distortion
YOU SHOULD NOT PLAY CD,S IN SURROUND SOUND,SWITCH TO STEREO ONLY FOR CD,S AND OTHER MUSIC SOURCES.
HOPE THIS HELPS.
Dec 17, 2007 | Onkyo TX-SR500 Receiver
JVC DVD player plays with distorted sound
Have you tryed a differant audio input on another set or on that same set. Are the audio cables good?? If all this is ok then the D/A converter inside the unit is defective and most likely it wont pay to repai sorry
May 25, 2006 | JVC XV-N40BK DVD Player
NAD T760 Logo
78 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
