Question about Sylvania G-Netbook
Can i adjust the memory or is it fixed. if so how?
    Sergeant:
  • 169 Answers
Why do you want to adjust your memory..?
you only adjust your memory if its not working well..
NOTE
You dont adjust memory ordinarilly , you can only upgrade a Memory or even Viceversa..
remember to Rate eme
Posted on Jan 01, 2011
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues.
Try searching YouTube videos or this may be helpful:
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Setting the Bobbin Tension on your sewing machine
Liz Kettle adjusting your bobbin case tension 1 wmv
How to fix Tension Don Panic
Sep 27, 2015 | Janome Memory Craft 3000
Memory card error
This video covers troubleshooting steps for camera memory card error.
And this webpage goes into more detail
http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html
May 13, 2013 | Canon PowerShot SD200 / IXUS 30 Digital...
Temperature and adjust refrigerator panel does not work.
problems exist in its electronic control panel that is damaged, this problem should be solved by replacing one block electronic circuit in the control panel. damage is usually caused by a memory of the troubled program. actually if you know you can fix the electronic control panel of the electronic circuit itself, simply replace the IC EEPROM or memory alone. follows with Cristal oscilator usually must be replaced too
Jul 24, 2010 | GE PSS26SHRSS Side by Side Refrigerator
HTC 4350 low memory message, all possible files & data already moved to storage card; memory seem to be ''locked''; how do i fix this?
Tap on Start >> Settings. Go to System and tap on Memory, check how much memory is free in there for Storage and Program both and if possible adjust the memory allocation.
Oct 29, 2009 | HTC Touch P3450 Smartphone
Same problem
I have a guess W15514G2.. and I want to change the day in the watch, In the first click I am able to adjust Date on one side and month on the other side, the next click makes me adjust the time. But what about the Day? How do i adjust that? Help me
Jul 13, 2009 | Cell Phones
Auto adjust problem on dell monitor.
I can tell you it was most likely caused by the movement of the machine instead of the memory chip. I would suggest doing a few things, first unplug the monitor from the computer, then power on and through the menu in the screen hit "Factory reset" then power off, from there plug it back into your machine and tighten the screws until they are tight - hey I'm guilty of the sloppy plug myself but it will eliminate the need to check it later. Now reboot the computer with the monitor on. Hope this helps.
Apr 01, 2009 | Dell Computers & Internet
Rastor needs adjustment on 60v500a
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Jan 08, 2009 | Hitachi 60V500 60" Rear Projection...
Slow pc
Hello juliet_34x,
Whats also important to perform when you up your memory to 2 gig is to adjust your Paging File as well. At 2 gig of primary memory, you will need to adjust the Paging File to 3000 (2 GB X 1.5) and Maximum size to 4092. In addition, if your computer was performing slow before the memory upgrade, you should perform disk cleanup and defrag (this will help alot).
Hope this helps and good luck.
Aug 25, 2008 | Computers & Internet
Channel Memory Not working
I can help with two solutions, if you wish.Please verify Model
# and mo / yr built off back of set.............T.
Aug 23, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Sylvania G-Netbook Logo
298 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
