Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Hi I have a Siemens SE26T252GB/01 dishwasher which won't drain. (The "check water" light comes on). I have checked all the filters/drains and I think the fault is the drain pump which I would like to replace. I can remove the side panels but cannot remove the base to get access to the pump. Can someone help with instructions or a diagram please? Many thanks
SOURCE: GE Dishwasher GSD4020Z07BB is leaking water and doesn't drain
yes...mine leaks at the door base as well
Posted on Jan 30, 2008
SOURCE: Dishwasher won't drain all the way
I have a siemens Model SL34A and it will run the whole wash cycle but at the end it is still full of water and will not drain . Tried drain declogger and checked all the hoses for clogges and dose not appear to be the probblem.
Posted on Feb 13, 2008
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
  • 161 Answers
SOURCE: Bosch SHU33A06/22 does not drain
I think so. Check for power at the pump. If so is it running. There are seperate pumps for drain and wash. It is also possible the impeller came loose and the motor is running but not turning the impeller.
Posted on Jul 03, 2008
  • 22 Answers
SOURCE: Check water light comes on
is your appliance a miele? normally this is causeb by blockages ( bit of plastic or paper wrapping/ milk bottle tops etc) inside the impeller of the main circulating pump (motor) restricting the flow of water the only solution is to fisically remuve the obstraction by temporarelly remuving the motor and cleaning not a simple job
Posted on Nov 13, 2008
Stops working part way through programme
It seems it is drain problem and check out your drain hose and drain pump for problems and clean all main motor and pump as much as you could do
Dec 09, 2013 | Siemens 24 in. SE25A266 ExtraKlasse...
Dishwasher started to wash then it stopped. Now there is water standing in the dishwasher and won't drain.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 22, 2011 | Kenmore 24 in. 16022 Built-in Dishwasher
The dishwasher won't drain completely. Water is left standing in the bottom of the tub.
Hi
Daniel
Aug 02, 2011 | Dishwashers
Whater not draining from the dish washer
Hi
Daniel
Aug 01, 2011 | Siemens 24 in. SE25A266 ExtraKlasse...
There is always water left in the drain at the bottom of the dishwasher, which gets sprayed back on the dishes so now my glasses have material on them and it gets baked on in the dry cycle....
Hi
Daniel
Jul 20, 2011 | Siemens SL85A705UC 24 in. Built-in...
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
Hi
Daniel
May 07, 2011 | Dishwashers
My dishwasher is filled with water and won't drain
Hi
Daniel
May 07, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
Won,t drian the water.
Hi
Feb 21, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
96 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
