Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Wash machine shakes and bounces when operating with a full load.
    President:
  • 2,468 Answers
You need to remove the control panel and 2 clips that hold the entire cover on then tilt cover toward you to remove outer cover then check the tub springs 3 of them if one broken it will be loose and bounce,also the drive block could be worn under the inner tub,the shipping straps or bolts need to be removed if the machine is new otherwise it will also bounce around
Posted on Jan 01, 2011
I have a Frigidaire gallery Heavy duty extra large capacity Front loading 2 way tumble action washing machine. It rocks,shakes when it is in the spin cycle. I got it levelled, still it continues to...
If your transport bolts are removed and if the springs or shocks are in good order, make sure the machine is not standing on a tiled floor. No matter what, it will bounce all over the floor then. Place machine on a concrete floor and retry.
Aug 05, 2010 | Washing Machines
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wash bounces all over the place
nothing, i'll live with it. thanks for your reply
Apr 08, 2009 | Maytag Washing Machines
Frigidaire Front Load GLTF2940 full of pet hair
Why dont you shake out the maximm hair before loading into machine?
Apr 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Shaking
Most common cause for the machine to shake during the spin cycle is due to a unbalanced load. A load of a couple of small bulky items or a small load in general may not be able to distribute the weight properly causing the machine to be unbalanced. It is best to wash full loads whenever possible. We have a brand new front loader as well, our first load about took the walls down...We just tossed a couple things in to see how it worked....thats how I learned to wash full loads. Now with the knowledge of why it shook so bad, we have had no more problems. Hope this helps
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machine Shaking
Please take the time to give this a fix ya rating
clarkco
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
164 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
