GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Jan 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
J KP85W0D1WW microwave door liner on inside is falling out. Is it possible to replace door?
Anonymous
Level 3:
President:
  • Master 2,468 Answers
  • Posted on Jan 01, 2011
Anonymous
Master
Level 3:
President:
Answers
2468
Questions
0
Helped
707035
Points
7484
Yes you can replace the door assembly,but it will be as much or more than just replacing the entire unit
How to remove and replace microwave door key
You must remove the inside plastic door liner that surrounds the glass. It just snaps into place so usea small flat blade screw driver to pry it out. You can then replace the door key.
If the spring has detached from the door a the outer door must be replaced.
2answers
Emerson mw9117w
The handle screws are accessed by removing the door liner which usually snaps in place. Often, the tabs that hold the liner in place will break off during disassembly. Officially, after working on a microwave door it should be tested for microwave leakage.
1helpful
LG door panel separating
DO NOT use this microwave in the current condition it is in- please! Although microwaves do not emit ionizing radiation, it does emit non-ionizing radiation and electromagnetic fields- and there is a lot of research studies being done possibly linking microwave exposure to cancer.
If your microwave is in that bad a shape, bring it to an authorized microwave repair shop or junk it and buy a new one.
For replacement parts, repair videos, and manuals: http://www.lg.com/us/support/parts-accessories
GE microwave J KP85W0D1WW is not heating up food anymore? Can it be repaired?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
The insulation around the inside of the microwave oven door has fallen down. New Whirlpool over the oven microwave. I can see the insulation through the glass. Tried to lightly tap the door to make it fall...
I called Whirlpool Corp and told them about the problem. They are sending a factory authorized repairman immediately to repair or replace the door. Thanks to FixYa, I found a solution!
Respectfully,
Jim
6helpful
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Microwave door tension spring
See answer here http://www.fixya.com/support/t265705-microwave_door
in different thread.. Basically have to pry plastic trim ring off inside of door with putty knife (careful, it cracks easily) to get to screws on bottom of door. See second pic. Top screws are easily accessible from inside of door. Spring can easily be replaced by hand once you get adequate access. You'll need a fairly stubby right angle screwdriver (I used a cut-down #2 Phillips bit and small Vice-Grips as a make-do) to get to the screws. Also need Torx (T10, I think) to detach the shock absorber doodads from the door where they attach above the hinges. If you're just starting to take the door apart, be careful when you take out the top 2 screws on the inside-- they hold the inside plastic piece on , but they also hold the whole outer stainless/ glass/ handle piece on. It just slips in at the bottom, so be ready to slide it out when you take these screws out.fea33aa.pngc391898.jpg
IN CABINET MICROWAVE
Hello JudyKitz,
That mesh is there to protect the user and acts as a shield to contain microwave energy to the cooking compartment. Never compromise that material.. You can purchase replacment liners at this site http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130353 If you prefer, you can get a thin piece or sheet plastic cut to fit at many local hardware stores or home centers..You may want to make a paper template or take accurate measurements with you for that method.. Hope this helps you..
NN-GT576SBPQ door falls off
I would think your door hinge has come loose, or the door may be cracked.
This should be repaired before the microwave is used to prevent the possibility of burns due to microwave leakage.
You can locate an authorized servicer or contact Panasonic support here.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
