Question about Maytag Washing Machines
My top load washer will not agitate, all other cycles work fine. Transmission problem?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of your machine?
Posted on Jan 01, 2011
Washer wont agitate, pops breaker
Could be the gears/transmission for the agitate cycle are jammed, the motor then freezers, creates an overload and the breaker pops.
Jan 27, 2014 | Maytag Ensignia MAV4758AWW Top Load Washer
My washing machine spins but does not aggitate what do i need to do?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore installation and operations manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also look at the Whirlpool parts list for top load direct drive commercial washers (the consumer model is basically the same.)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Whirlpool / Kenmore top load direct drive washer uses an agitate shaft from the transmission with splines on its' top that fit into slots in the agitator. If the slots in the agitator are damaged / worn, the washer may not agitate.
Remove the fabric softener dispenser, remove the top agitator cap (a short screwdriver works well), and you'll see a 1/2" square drive bolt. Use a 1/2" socket extension to remove the bolt, pull up on the top agitator and carefully turn it over. You should see four plastic "dogs" that allow the top agitator to turn one way only. If they are worn, they are easily replaced.
After removing the top agitator, you should see a bolt (I think it's 5/8").
Carefully remove the bolt and the rubber washer under it and the main agitator should come off. You'll see the top of the transmission agitator shaft with it's splines. Check them and the slots inside the main agitator.
If the splines on the transmission agitator and main agitator are OK, the washer spins and drains and the timer moves through its' cycle, the problem points to an agitate gear in the transmission itself.
See the parts PDF for the transmission.
Replacing the gear in the transmission is a bit complicated (and messy) but it's a lot less expensive than a $170 transmission.
If you decide that you want to work on the transmission (it's not really that hard) post another question on Fixya and I or someone else should be able to walk you through it.
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
Magic Chef 20lbs hd won't agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Jul 23, 2009 | Magic Chef CAV2000 Top Load Washer
Kenmore 80 topload washer agitation cycle noisy and high current
Sounds like a motor problem drawing to many amps dimming lights. Check drain pump to see if pump has obstruction in it causing resistance. Run machine while pump is off to see if light dim.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Roper washer will not agitate
could be the transmission or the drive motor to transmission coupling. You say the agitator doesn't work but it washes fine please clarify your problem.
Jan 12, 2009 | Roper RAS8445KQ Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
16 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
