I am unable to switch off my apc system BACK UPS ES-500. When I pressed the button the system does not switch off. So I just leave it to automatic turn off. The button is push type. I think it may due to metal contraction because the problem is majorly in winter seasons. Please help me..
  • 168 Answers
SOURCE: APC UPS no power
The unit might have a dead battery, blow fuse, or a bad board.
Your best bet is to talk to an APC rep. Worst case, APC has a trade in program, and can give you a discount on a new one.
Good luck.
Try Chatting with an APC Support agent online.
Here is their direct link:
http://www.apc.com/support/chat.cfm
Chat with a Support Agent
Chat with Support for immediate assistance with your APC Back-UPS, Cable, Surge Protection, Notebook and Mobile Device accessories and products. Agents are available Monday through Friday from 8:00 a.m. to 8:00 p.m.
Posted on Feb 07, 2008
  • 33 Answers
SOURCE: UPS Switching off while working
Hi kumaraswamy5,
it seems that either the UPS is connected to an outled which isn't grounded properly or the battery inside of the UPS needs a replacement.
On APC's website you can find the compatible batteries for your device and where to order them. Replacing the batteries is very easy so don't be afraid of that!
Greetings from Germany,
noris017
PS: Please don't forget to rate this advice after you've tested it out! Thanks in advance and have a nice day!
Posted on Feb 25, 2009
  • 19 Answers
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Posted on Dec 30, 2009
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
  • 111 Answers
SOURCE: i want to connect an automotive external battery
you can get an old ups with bad batt. cheap,take out bad batt,hook yours in,or get a small battery charger(2/10 amp),an inverter(about a 1000watt),plug in charger, hook to batt.,then connect inverter to batt,plug computer into inverter,turn on inverter and you should be good, keep in mind all inverters are not same,get one at a computer store that will handle what your computer draws(watts), if your ups is good and you're trying to expand batt. capacity, the batts. in the ups are not lead/acid,so it's not a good idea to connect different types and sizes or an old batt. to new one,chargers are different too,what I described at top is basically a ups
Posted on Feb 01, 2010
  • 401 Answers
SOURCE: red light and beeping
change the battery
Posted on Mar 11, 2010
APC BACK- UPS ES 500 IS NOT SWITCHING ON !
Quite likely that the battery has died in it .they do not like being put to bed for extended periods of time .
Aug 31, 2015 | APC Computers & Internet
Apc us[p es 500 timer always reset
sounds like the battery is low or has been disconnected.
Mar 11, 2014 | APC BE500R Back-UPS ES 500 (BPAPWBE500R)...
My Apc Back UPS Es 500 did not charge and then there is power when I turn on the switch. How could I repair this problem?
Good Day! Try changing the battery. please visit apc's service center for battery replacement. it will only take 3-5 working days. once done, your ups will be as good as new.
Nov 09, 2010 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
All battery charge lights flash simultaneously.
THIS seems the be the answer to your question. Hope this helps
Apr 29, 2010 | APC Smart-UPS 1000VA UPS System
Need charging instructions for apc back-ups es 350
Take off the bottom cover and make sure the battery is connected (both terminals).
Plug the unit into a wall outlet.
Press the power button to turn it on. Leave it plugged in for 8 hours to charge the battery. Do this with nothing plugged into the unit.
Done.
Aug 08, 2009 | APC Back-UPS ES 350 UPS System
My 500-A Ups is making Buzzing sound.
APC 500VA ups meant for 1 Desktop and one montiro it will have battery backup for 10 to 15 minutes for the above.
Normally, You should make the raw power connected to UPS should be always ON.
The power cables of CPU and Monitor is connected with UPS. When not in use, please press the Button available on the UPS.
The UPS Life is normally 2 to 3 Years only. Now you are getting the sound and Red Light will always blink and not allow to use the system.
Better replace the 12 Vols battery to get some more life for the UPS.
And check for any loose connection of the power cables connected with Raw Power and UPS System.
Jul 19, 2009 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
