Question about Frigidaire ATF6000ES Front Load Washer
After wash, clothes are soaking wet. I tried the drain and spin cycle again and while the machine hums, nothing happens. How can I take care of this?
My first one did that and it was a problem with the door lock. The door was loose and the lock light was going on but it was not really locked or not tight enough and it would spin for a minute slowly and then reverse and my clothes would still be wet.
I kept thinking I just didn't know how to use it. But they had to bring me another machine and take it back.
Hope that helps - now I love it
Posted on Jan 02, 2011
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
Cloths are wet after spin cycle
ceck for kinks in the drain hose .if you have a wet vacuum try sucking on the drain hose, or fallow the drain hose into the back of the unit to see if there is a blockage or a belt off .. jay florida
Nov 23, 2011 | Maytag EPIC MFW9700S Front Load Washer
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
Spin cycle is not working. clothes are soaking wet when cycle is finished.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
The washer will not spin when it gets to the spin cycle, when the washer stops the clothes are still soaking wet?
heatman101
Oct 22, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
583 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
