Crinkled paper When we print the copy comes out wrinkled. We found two different shaped large screws in the copier. One gold colored screw was on the inside of the copier on the front lip and the black screw (has as varied size on the stem of the screw) was found under the front lip inside on the bottom under the black piece. We think the screws belong to something that keeps the paper from wrinkling . Please advise Kathy
Sound like you fuser is bad
Posted on Jul 09, 2008
How do I stop the paper from crinkling prior to printing in Canon D320
check the whole paper flow. special look out for things in the printer that don't belong there, like a paperclip or screws of paper.
sometimes things fall in a printer and can spot all the fun.
Jan 21, 2015 | Canon Office Equipment & Supplies
Envelope printing error - when printing from the MP tray, envelopes are wrinkled
nothing im afraid mfps crinkle copiers all you can do is try to reduce the wrinkle try putting the flap inside the envelop sorry but other than that's theres not much your can do
May 14, 2014 | Kyocera Office Equipment & Supplies
All printed pages come out with random "V" type
Check to see if there's anything stuck onto the fuser rollers. It sounds as if there may be some residue dirt that prevents the fuser to do its job. It may be that someone tried to print on a self-adhesive paper that was not meant to go through laser printers, and somehow a triangular shape got stuck on the rollers.
On the other hand, if this V shape is just a wrinkle that's different on every printout but preserves the general V shape, then you may be looking at the paper guidance plastic "fingers" inside the paper tray. See that the paper is freely movable and it's not pressed too hard. Also, see that you don't use lighter paper than 80g/m2, although printers say they can handle lighter paper, 80-120g/m2 is still the best thickness for lasers.
If you found this post informative and helpful please vote for it with a Thumb Up. Thank you.
Jan 18, 2011 | Samsung CLP-610ND + Demo Laser Printer
I had a paper jam and was able to get paper out but whenever I print something there is a thick line that does not copy down the middle of the paper and a crinkle sound like paper is stuck inside the...
Bad news, the "golden'" paper is actually a piece of the fuser film of the printer. Out of experience i have found that a new fuser film costs almost as much a a new printer.
Found this link that may be usefull in making a decision whether to replace the fuser or buy a new Printer :)
http://www.precisionroller.com/fuser-assemblies---units-for-canon-imageclass-d760/products.html
Sorry for the bad news
BD
Sep 07, 2010 | Canon imageCLASS D760 All-In-One Laser...
The paper comes out wrinkled and makes the printing off, doesn't look nice and clean. The machine even sounds different like you can hear it crinkle the papers
You didn't list the make and model but it is safe to bet that your fuser is used up...call your tech support line for your copier since that module needs to be changed out by a trained technician.
Sep 11, 2009 | Office Equipment & Supplies
Paper is coming out wrinkled in one spot
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Jan 30, 2009 | HP LaserJet 2840 All-In-One Printer
Printer only prints on the left side and wrinkles up the paper on the left side
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Jan 17, 2008 | Ricoh Aficio SP-C210SF Printer
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
172 people viewed this question
k24674
jasbo
jasbo
