Question about Whirlpool Duet GHW9150P Front Load Washer
I keep getting an F11 code displayed and the troubleshooting section of the manual only says it's an electrical problem. If I hit cancel and then hold start, sometimes it will begin again where the cycle left off. What is the real problem?
    President:
  • 2,468 Answers
Check all wiring between the central control unit board and the motor control board in the lower area fore breaks and unplug and replug in any connection to make sure theres no corrosion on any contact points,also check for worn or loose motor parts as in belts,pulleys,if nothing is found then you will need to replace the central control unit first and then possibly the motor control unit next
Posted on Jan 01, 2011
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
I keep getting an F11 code displayed and the - globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn I keep getting an F11 code displayed and the - globul1a.gifmponents globul1a.gif Check MCU I keep getting an F11 code displayed and the - globul1a.gif="http://i.fixya.net/uploads/images/globul1a.gif" alt="globul1a.I keep getting an F11 code displayed and the - globul1a.gifh_mi" /> Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
My machine keeps stopping mid cycle with an f11 error code, what does this mean?
The troubleshooting section of my manual gives a Generic fix for F codes other than F20,F21,F22 as "Select stop twice to cancel the cycle.Select DRAIN & SPIN if there is excess water in the washer. Re-select cycle and press START If problem remains, call for service."
Not much help! Try checking the inflow by removing the hose to see if there is any debris in the inlet (rust etc.) Also could be a balance issue. Rearrange load and restart the cycle.
Or it could also be a leveling issue. Use a level to see if it needs to be raised or lowered by turning one or more of the "feet" with a crescent wrench to level the unit.
Jun 27, 2014 | Kenmore HE3T Washer
I am getting a flashing signal on the timer display that says f11. The washer stops filling and I have to cancel the cycle. The owners manual says that this is an electrical problem I have cycled the...
The owner's manual is not very clear in its explanation! When it refers to 'electrical' problem it really means that the problem is not to do with anything mechanical (water, motor, door not locked etc) rather than 'electrical' being the actual power/ breaker supply.
Whirlpool's 'F11' refers to 'communications error, control unit'- 'electronic' would be a better description. Sorry but this requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I was having the same issues as with the F11 Error code and if I remember correctly the machine did say "F11". But now the machine stops and beeps several times just as before it displays a...
An F11 code says there's lost communication between the CCU circuit board and the MCC circuit board. The true problem (and the basis for many other problems) is bad solder joints on the CCU circuit board. There are bad solder joints where the spade connectors and the relays (5 of them I think) are supposed to be securly soldered to the CCU board. The CCU is located in the machine, top, back, in a plastic case. The repair is fairly easy if your up on soldering techniques. If not, take out the CCU case with board and this response to a good appliance repair shop and they should be able to help you out. There should also be a technicians packet taped to the inside cabinet that is helpful in troubleshooting different problems. Just remove the panel under the door (three screws at the bottom of the machine) and it should be taped up on the side of the cabinet. Good luck.
Feb 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
