Question about Refrigerators
Water is leaking from the top panels behind the control. Ices up periodically in same location. We removed some items to get better air circulation, per the manual trouble shooting....problems continue. Saw water leaking like a slow running faucet for about 30 seconds.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 01, 2011
Water fills washer
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Jul 09, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
The water will not stop going into tub in a large load setting only. It works in all other settings.
May 14, 2014 | Frigidaire FEX831CS Top Load Stacked...
Simpson top loader overflows
Feb 21, 2014 | Frigidaire FGX831C Top Load Stacked Washer...
Water overflows
Feb 16, 2014 | Frigidaire GLWS1233A Top Load Washer
Washer overflows
Feb 13, 2014 | Frigidaire FGZ831A Top Load Stacked Washer...
Problem with the air flow water cime out
There is a ventilator mechanism on the top right corner, behind the control panel / front cover.
******TURN THE POWER OFF AT THE BREAKER BEFORE STARTING, BE SURE POWER IS OFF ******
Open the door; remove all of the screws that hold just the front panel (not the controls panel). These screws are located on the inside of the door, around the outer edges. The front door panel will be able to be removed. Close the door with the front panel removed.
***IMPORTANT be sure nobody will come in contact with the exposed wiring (especially little kids) *********
Turn back on the breaker, turn on the washer, and run a quick rinse cycle. See where the water is coming from.
On my washer (same model) i had to replace the entire vent kit (sears parts ~$40.00) Call them with your model and serial number, or search online. Removal and replacement was very easy, and it did fix my leaking problem. Checked with the front door panel off and a quick rinse before I TURNED POWER BACK OFF and put the front cover back on.
Root cause?? From what I can tell, the solenoid stopper hardens over time, which allows for water from the spray arms to leak past.
Get it fixed now before you smoke the motor or control card. My part number was ABT35083501 be sure to double check model before purchasing.
Dec 04, 2009 | LG LDS4821ST Stainless Steel 24 in....
Water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Sep 02, 2009 | Refrigerators
Water leaking into RV
If water is coming in through the filter grill, then your drain trough is clogged. Go up to, remove cowling, and flush trough drains out. That will take care of water getting inside. I like to use pipe cleaners and poke through drain holes on either side of the trough.
Excess water is also caused by poor air circulation and coils beginning to freeze up. All is well for a while, until the compressor finally turns off, then you turn fan off and water pours from above. So, while up top, also clean the coils of both the evaporator (located above and behind filter opening) as well as condenser. When cleaning evaporator, take care not to spray water into the inside of the coach. You should not need a special cleaning product unless the coils are very nasty, then use a non hazardous cleaner (you will get some on the carpet down below) such as Orange based. Also change your filter every 100 hours of the fan running (regardless of compressor) to minimize air flow restriction.
Aug 22, 2009 | Coleman Heating & Cooling
Kenmore Washer/Dryer Combo Model # 11088752792
The problem is usually attrbuted to leak-by on your Water Inlet Valve (also known as a "Mixing Valve" on some models). The valve can become clogged or corroded with rust and sediment over time and not seal completely when shut off. This is especially true if you live in areas where you have hard water, or use well water. If the diaphragm inside the valve does not seat correctly, this will cause leak by. It may be very minute, but will become noticeable over a period of time. The washer does not have to be turned on for this to occur. You can try to remove the valve and clean it thoroughly to see if this will help, but if you are going to to go the route of removing the valve, it would make better sense to simply replace it instead of having to possibly go through the process twice. A replacement valve can be found at searspartsdirect.com. Just type in your model number and look under the "Washer Cabinet" heading for item number 5 (part #285805). This is a fairly simple repair that is also inexpensive. To replace:
1. UNPLUG the appliance and shut off the water at the water taps.
2. Disconnect the fill hoses from the back of the washer.
3. Remove the panel directly above the washer top.
4. Remove the washer top panel.
5. The fill valve will be located in the left rear (as viewed from the front) behind the wash tub.
6. Remove the dispenser hose and electrical connectors from the water inlet valve.
7. Remove the mounting screws that hold the valve to the rear panel.
8. Reinstall new valve using the above steps in reverse order.
The repair is pretty straight forward. If you have questions, please let me know. I hope this helps you.
PS In the interim, to keep the tub from filling up with water, shut of the taps when not in use. This may buy you some time until you are able to replace the valve.
Oct 24, 2008 | Washing Machines
Cold air circulating fan
behind back panel inside freezer. take back panel off
Oct 19, 2008 | LG Refrigerators
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
