Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Where is the fuel filter located? I have a filter and need to install it.
  • 7,733 Answers
INSIDE THE FUEL TANK.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Posted on Jan 01, 2011
Fuel Filter
A combination fuel filter/pressure regulator assembly is used, which is located on the top of the fuel pump module.Here's a link on replacing the fuel filter.
Repair Guides Fuel Filter Removal Installation AutoZone com Here's another link on relieving the fuel pressure before replacing. Repair Guides Fuel Filter Removal Installation AutoZone com
Apr 10, 2016 | 2005 Dodge Neon
Need to know where the fuel filter is located
FAQ: Fuel Filter Replacement ' Briggs & Stratton Engines
www.briggsandstratton.com/us/.../fuel-filter-replaceme...
Briggs & StrattonWith this Briggs & Stratton FAQ, you'll learn how a fuel filter works in small engines ...properly strain the gas before it reaches the carburetor in your lawn mower, snow ...and uneven operation; Clean filters conserve the amount of gas you need ... The fuel filter will be located either inside the fuel tank or fitted into the fuel line ...
Servicing the fuel filter - Briggs & Stratton
www.briggsandstratton.com > www > Support > FAQs
Briggs & StrattonIf you still need help, you can submit your question by clicking the Ask a Question tab.... Some filters are located inside the tank, others are fitted into the fuel line between the tank ... The size of the holes in the filter will determine the largest particles that can get through the filter, and the number of ... Lawn Mower Engines ...
Lawn Mower Engine Fuel Filter Installation - Briggs ...
Jan 01, 2016 | Garden
Where is the fuel filter located on my 2001 ford explorer and can i replace it my self
Step 1 Park the Explorer and apply the parking brake. Open the hood and locate the fuse box near the battery. Open the fuse box and locate the fuel pump relay. Remove the fuel pump relay by gently pulling up on and and rocking it if necessary. Start the engine and allow it to run until it stalls. Once the engine stalls, turn the key off and remove it from the ignition.
Step 2
Put on your safety glasses. Climb under the vehicle on the driver side near the rear tire. Locate the fuel pump protective shield near the fuel tank. Remove the two shield mounting bolts with the appropriate socket. The fuel pump is located behind the shield. It is about the size of a soda can and has three lines coming off of it.
Step 3
Remove the two lines that are on the same side of the filter by pushing the colored tabs of the fuel line together and then pulling the line off. On the single line you need to remove the fuel line retainer by prying it off of the line with the flat-head screwdriver. Disconnect the fuel line by using the fuel line release tool. Clamp the tool around the filter side of the fuel line, then push the tool into the fitting until you feel a snap releasing the retainer spring, and pull the line from the filter. Loosen the fuel filter clamp with the screwdriver. Remove the fuel filter from the vehicle.
Step 4
Install the new fuel filter into the clamp with the arrow on the filter pointing towards the front of the vehicle. Tighten the clamp until it is snug. Install the single line by pushing it onto the filter until you feel it snap into place. Push the line retainer onto the line until it snaps into place. Install the other two lines onto the filter until you feel them snap into place. Install the fuel filter shield and tighten the bolts to 89 inch-pounds with the torque wrench.
Step 5
Install the fuel pump relay and close the fuse box cover. Close the hood. Turn the ignition key on for 10 seconds. Turn the key off and then back on to pressurize the fuel system. Check for leaks around the fuel filter. Start the engine and check for leaks one more time.
Dec 07, 2014 | MagnaFlow 2001 Ford Explorer - XLT, 4.0L...
How can i change the fuel filter on a 2004 hyundia sonata?
NOTEThe fuel filter is located underneath the car, near the fuel tank.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    Negative battery cableFuel supply and pressure linesFuel filter bracket, if equippedFuel filter
To install:
Fig. Remove the fuel filter
  1. Install or connect the following:
    Fuel filter and torque the mounting bolts to 18-25 ft. lbs. (25-35 Nm)Fuel filter bracket, if equippedFuel supply and pressure linesNegative battery cable
  2. Start the engine, check leaks and repair if necessary.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
To install:
To install:
    Sorry, there are no parts available for the selected vehicle: 2004 Hyundai Sonata 2.7L MFI DOHC 6cyl.
Nov 24, 2012 | Hyundai Motor 2004 Sonata
Locate fuel filter on 2005 ford focus tdti
Ford Focus 2000-05
Removal & Installation
Print
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE The fuel filter is located underneath the vehicle in the area of the rear suspension.
  3. Raise the vehicle.
    NOTE To remove the lines, press the quick-release tabs on the connectors.
  4. Remove or disconnect the following:
    Evaporative Emissions (EVAP) vapor line Fuel filter lines Fuel filter and bracket assembly Fuel filter
    Fig. Location of fuel filter and lines.
To install:
    Fuel filter Fuel filter and bracket assembly Fuel filter lines EVAP vapor line
  2. Start the engine and check for leaks.
  4. Remove the fuel filter bolt and remove it from the bracket.
To install:
  1. Position the fuel filter into the bracket. Ensure the fuel flow direction is properly aligned.
  2. Install and tighten the fuel pump bracket bolt.
  3. Lubricate the fuel tube fittings with clean engine oil. Align the fuel tube fittings and press together until a click is heard and then pull on the fittings to make sure they are fully engaged.
  4. Start the engine and check for leaks
May 09, 2012 | 2005 Ford Focus
2000 ford focus in line fuel filter where is it located
Hi, it's back by the fuel tank.
NOTE: The fuel filter is located underneath the vehicle in the area of the rear suspension.
  1. Relieve the fuel system pressure by removing the fuel pump fuse from the battery junction box, starting the engine, and allowing the engine to idle until it stalls.
  2. Raise the vehicle.
  5. Fig. Location of fuel filter and lines.
To install:
Mar 31, 2011 | 2000 Ford Focus
Location of fuel filter.
Fuel Filter Removal & Installation To Remove:
  1. Place the vehicle on a lift.
  2. Release the fuel system pressure.
  3. Disconnect the negative battery cable.
  4. Disconnect the fuel lines from the fuel filter CAUTION
    Some residual fuel will remain in the fuel filter after disconnecting the fuel tubes. Carefully drain the remaining fuel into a suitable container.
  5. Remove the fuel filter.
To Install:
  1. Install the filter in the bracket clamp.
  2. Connect the fuel lines to the filter.
  3. Connect the negative battery cable.
  4. Pressurize the fuel system and inspect for leaks.
Aug 10, 2010 | 2004 Lincoln Town Car
How to change fuel fillter
2002 Hyundai Sonata 2.4L MFI DOHC 4cyl the Fuel Filter is located uUnder vehicle, driver side, below seating area, driver side of fuel tank, mounted on frame in fuel line.
Hyundai Car 1999-05 - Removal & Installation
NOTE The fuel filter is located underneath the car, near the fuel tank.
    Negative battery cable Fuel supply and pressure lines Fuel filter bracket, if equipped Fuel filter
To install:
    Fuel filter and torque the mounting bolts to 18-25 ft. lbs. (25-35 Nm) Fuel filter bracket, if equipped Fuel supply and pressure lines Negative battery cable
To install:
To install:
Hope this help to solve your problem.
Apr 24, 2010 | Hyundai Motor 2002 Sonata
Where Is The Fuel Filter Located On A 2003 Ford Explorer V8 And How Do You Change It?
  1. Disconnect the battery ground cable.
  2. Properly relieve the fuel system pressure.
  3. Raise the vehicle on a hoist.
  4. Remove the bolts and the fuel filter heat shield.
  5. Remove the nuts and the fuel filter shield.
  6. Disconnect the quick release and spring lock couplings and remove the fuel filter.
To install:
  1. Remove any fuel line caps.
  2. Install the new fuel filter, connecting the quick-release and spring-lock couplings.
  3. Install the fuel filter shield.
  4. Install the fuel filter heat shield. Torque the bolts to 15 ft. lbs. (20 Nm).
  5. Reconnect the battery ground cable.
  6. Lower the vehicle.
  7. Start the vehicle, check for leaks and repair if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 26, 2010 | 2003 Ford Explorer Sport
Where is it located? The fuel filter. My 2003 KIA sorrento will not accelerate up hills. Either hwy or city. On level ground it is fine. Is the fuel filter possible my proble. AGain if so, where is it...
For Kia Sorento 2003-2005 the fuel filter is located inside the fuel tank and is replaced with the fuel pump as an assembly.
Fuel Pump - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    Rear seat Access cover Fuel pump electrical connector
  3. Relieve the fuel system pressure.
    Fuel lines Fuel pump and filter assembly
To install:
    Fuel pump and filter assembly Fuel lines Fuel pump electrical connector Access cover Rear seat
Hope helped with this (remember rated this help) Good luck.
Nov 19, 2009 | 2003 Kia Sorento
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
18 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
