Question about Kiragames Unblock Me FREE
Please send the solution to Relax Mode Advanced level 115. Thanks.
  • 16 Answers
Here is the solution :)
Posted on Jan 02, 2011
Hello how doi adjust the left and right balance for the left and right channel level
The only 'balance' is to adjust the channels relative to each other with the test tones.
http://www.retrevo.com/support/Pioneer-VSX-24TX-Receivers-manual/id/386ag014/t/2/
Page 29.
The "Effect/Channel Select" button on the Remote (left of the Menu button), will let you change the level to any channels while listening to a program. Page 22
"EFFECT/CH SEL +/- buttons (See p.38)
EFFECT : Use these buttons to increase or decrease
the amount of effect applied in a DSP or Advanced
Theater mode. When the amount of effect is
increased in a DSP/Advanced Theater mode the
characteristics of that mode become stronger and
more noticeable. The scale ranges from 10-90 with 70
as the default setting. First turn on the DSP/
Advanced Theater you want (by pressing the DSP/
Advanced Theater button until you get the mode) and
then increase or decrease the amount of effect.
CH SEL : You may want to adjust the channels when
listening to some sound sources. Use this button to
select the channel you want to adjust.
+/- : Use these buttons to select the amount of effect
in a sound mode and to adjust the channel"
Jan 16, 2011 | Pioneer VSX-24TX Receiver
Dear Benq Would you please send me the function of the five buttons under the bottom right of my T221W screen? Many thanks, Richard Hinder
1. Enter "setup" mode or "click" to go "down" one menu-level.
2. Go "up" one menu-level.
3. Up one line inside a menu.
4. Down one line inside a menu.
5. "Exit" from "setup" mode.
Maybe, in a different order!
Oct 14, 2010 | BenQ T221W Monitor
Xl-115 Automatic setting not working?
your sensor board has failed , a realy common problem , most if not all are dead and no parts are made for it ...... you do not need the sensor anyway it was only installed as a knee **** reaction to fda worrys of ozone levels over 0.05 ppm in bedrooms . so the board was installed to cut at 0.05 ...... it was a failure , so a bypass switch was added to get around the problem board ... just set on man , adjust for your sq ft ... you will be fine
Sep 08, 2009 | Ecoquest Living Air Classic Air Purifier
Cant send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 27, 2009 | Lexmark X6170 All-In-One InkJet Printer
Cannot send a fax
Apr 29, 2009 | Lexmark X4270 All-In-One InkJet Printer
Can't print entire pdf documents only first page.
Try this
For Adobe Acrobat Professional 9:
  1. Choose File > Print.
  2. Click on Advanced.
  3. Choose Postcript Options.
  4. Under Font and Resource Policy, select "Send for Each Page".
  5. If "Print as Graphic" is checked, it must be unchecked, as well as "Send As Group" if it does not uncheck itself when you select "Send for Each Page"
  6. Save it as a custom configuration.
Jan 16, 2009 | Office Equipment & Supplies
Underexposed image on Auto mode
You can change the ISO setting also to Auto. If you have the advanced guide (see pp 80, 107).
Press the ISO button it will switch from various ISO setting to AUTO.
Do remember in Bright light , a lower ISO number like 80 will give you very fine images, while as the light level goes down, the ISO number will change to a higher number and the image will become more grainer.
I hope I could answer to your query.
Please do rate. Thanks
Jan 14, 2009 | Canon PowerShot S5 IS Digital Camera
Wireing problem
Relax man order the Service Manual for your bike and your golden!,
Nov 10, 2008 | 2004 Bajaj Caliber 115
Just bought my Vaio yesterday....
Hi
First of all just relax, its not very serious issue. You can start the computer in safe mode. All you need is click on F8 key during the boot process right after turn on the computer. Once you get into advanced safe mode, you can perform system restore. If you are using Vista on it you can just type System Restore in start search area and get into System restore option choose the date that system worked fine. After restore issue should be resolved. If you need further assistance please post.
Good Luck
Mar 06, 2008 | Sony VAIO PCG-K35 Notebook
Kiragames Unblock Me FREE Logo
717 people viewed this question
Top Kiragames Apps Experts
Bill Boyd
ray gallant
Are you a Kiragames App Expert? Answer questions, earn points and help others
