During a party there was alcohol spilled on the remote. is there a way to clean it or fix it or would i be advised to buy a new remote control?
the buttons are now not functioning correctly. eg. source button results in "unavailable" being displayed and the volume does not work.
Probably something spilled inside the remote. Most remotes are snapped together. Using a thin knife or similar tool carefully pry it alart. Use a q tip and rubbing alcohol to clean the circuit board and the rubber keypad contacts. Let dry and reassemble.
Either something was spilled onto the remote, or the remote itself is malfunctioning. You can try to remove the batteries, pop open the case with a flat head screw driver, clean the rubber buttons/electrical board with q-tips dipped in rubbing alcohol; or buy a new remote for under $20.
you must open the remote control and clean the keypads, from;humidity, dirty, oxide, corrosion and bad contacts, use contacts cleaner. very well.If you can use the alcohol ethylic to 75% better, 2) reset the code 3) try again. 4) otherwise you must go to the repair shop. for fix it. God bless you
open the remote and clean the keypads with contacts cleaner or ethylic alcohol to 75% , for dirty, humidity, corrosion, oxide, bad contacts. 1a) clean the contacts batteries and retigh the spring for better contacts 2) reset the code 3) try again. 4) if the problem persist go to the repair shop for fix it. God bless you
Try fixing your remote controller
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
you need to clean your remote with alcohol.open the remote and clean it with white alcohol,that should do it if not buy a new remote.you can probably get one at partstore.com..good luck.
Hi, I think you have lost your precious Remote because you don't do it by yourself if you have not any experience about electronics. You made a mistake to wash it out with alcohol and i think you didn't give time to dry it.And moisture was still there and you you connect batteries with it too.That's why you feel hot.It means that a short circuit has been occurred in it.My advise is to contact any expert nearby to you and avoid any new experiment on it.It can be repaired yet. Thanks.
Try taking it apart and cleaning the rubber number pad with alcohol and let dry before putting back together this should help.
It seems to have have something spilled on it.
