Question about Hunter (25417) Ceiling Fan
I cut the lights on with the remote and they popped loud and went out.. replaced all the bulbs but they wont come on
  • Barrett Palumbo
    Barrett Palumbo Jan 01, 2011
    does the fan come on, or total unit dead
    Sergeant:
    Champion:
  • 342 Answers
Remote control unit needs to be replaced with a OEM part go to the manufacturer site for parts or call them
Posted on Jan 01, 2011
Projector had been overheating so we cleaned out the filter. When it was turned back on there was a loud pop. We turned off and turned back on, red lights started flashing and the fan roared loudly and...
The projector lamp has probably failed. If it had been overheating, the glass for the bulb would be weakened and then eventually when turned on the glass shatters, the pop you heard. Bulb replacement is usually a straight forward user replacement item. Ebay is often your best choice to get a bulb at a reasonable cost.
Mar 29, 2011 | Office Equipment & Supplies
My hunter ceiling fan is not working and according to hunter technical support, I need to replace the remote control receiver (part # 8511204000) at a cost of 50.00 plus shipping.is there a way to by-pass...
If the product did not come with a manual control on it then yes you will have to use the remote. However, if the replacement remote will cost nearly as much as the ceiling fan itself you could simply purchase a new fan.
Feb 28, 2011 | Vacuums
I pickd up my prjector while it was on. i turned it over an i head a POP and all the lights went on so i pulled the plug now it wont turn on... what is the prob?
The POP sounds typically means the project bulb blew (just like a typical light bulb). You can take it into a repair shop to have the bulb replaced.
Feb 25, 2011 | Dell 2300MP Multimedia Projector
JVC AV-48wp55 Made a loud noise and went dead instantly.
WELL IF IT WAS A LOUD POP,YOU NEED TO REPLACE THE FLYBACK TRANSFORMER,GET THE MAKE AND MODEL # AND DATE OFF THE BACK OF TV, AND CALL MATS ELECTRONICS #1-800-628-1118
Feb 15, 2010 | JVC AV-48WP30 48" Rear Projection...
HL-R5656W Unit made loud pop and pic went black, ordered bulb but there is a loud crackling with some flashing going on when I re-inserted old bulb, is this the ballast that needs replaced?
Wait until you get the new bulb to determine that. The old bulb is probably arching as it tries to start.90% of the time the new bulb will do the trick.
Oct 31, 2009 | Samsung HL-R5656W 56" DLP HDTV
Same humming , but then goes off.
Color Wheel it is you can get one for around 95.00 up depend s on Part# BP96-00674A cost 113.69 Call Encompass Electronics 1-800-638-3328.Just looked it up they have it.
Sep 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
No picture, just sound
You need to replace your projection light bulb - the part can run from $100-350 depending on how you shop around, I would suggest ebay- as this was the cheapest route for me.
Feb 03, 2009 | Televison & Video
TV made popping sound and then shut off
You need to look in your owners manual for the telephone number and order a new bulb. It should cost about $200, but they will ship it overnight and minimize your downtime.
I've replaced 2 in my WD-52525 in the last 3 years, the first one went like yours did, very suddenly, with an audible POP!! The second one was preceded by an orange warning light, which the book says is a warning that the bulb has about 20 hours left on it.
To replace the bulb, UNPLUG THE TV, remove the left speaker screen, with a philips screw driver unscrew the bulb, pull it out by the handle, then replace it with the same type, in reverse order. This is a very easy replacement that does NOT need to be done by a service technician to complete.
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
Dec 10, 2008 | NEC LT 240K Multimedia Projector
Red light flashing while green light stays on
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Aug 19, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Hunter (25417) Ceiling Fan Logo
44 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
