Question about Empire DV-215 Direct Vent Natural Gas Heater
New gas Heatalator fireplace. Burner flame is blue at base but burning a 6-8 inch flame. Proffessionally installed, orfice change to LP as came from factory natural gas. Instructions say will soot like crazy for 10 hours to season ceramic logs. It has and it did.14 hours later it still is. Air mixture has been adjusted to fully open as per instructions. HELP Craig Folkestad
  • cragarf Jan 01, 2011
    thanks have a great new year!
  • cragarf Jan 02, 2011
    thankyou am checking reg pressure, same line as furnace, will that effect the furnace operation or my gas bill on my new furnace is really high. could that be the same problem? This is a new cabin and all installs arfe just a few months old
    Craig
  • Empire Master
  • 43,501 Answers
You may have to install a pressure regulator and cut back the gas pressure to get the flame to a level where it will not soot...
or if you already have a pressure regulator in the line then open the center of the regulator and turn the screw up a few turns at a time till it stops sooting...
This should get you running and enjoying your new fireplace..
heatman101
Posted on Jan 02, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Jan 02, 2011
    Check the pressure on the main regulator at the side of the house or on the tank...yes, it could affect the gas bills.... but for some reason this year everyone is complaining about their LP gas bills... seems to be no heat in the gas....
    Genius:
  • 1,015 Answers
The first thing I would double check burner orifice size. Sounds to me like it's much too big. Iwould also want to check regulator pressure to see that it is in the proper range. Hope this helps you.Thanks
Posted on Jan 01, 2011
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
Orifice installation
Yes, you do need to change the orifice when converting from LP to NatGas. The orifice hole for NatGas is much larger than that of LP.
Sep 06, 2014 | Home
Can anyone tell me why my direct vent fireplace flame looks like its in a wind storm. The pilot blows out as a rexult
Looks like too much yellow in the flame. That is normally caused by the mixing control on the gas feed tube being too closed. Trace the tube from the burner .....back toward the gas feed line....until you find the slip ring that controls the amount of oxygen that is mixed with the gas. Open is a small amount and light it. You should see a bit more blue color. If that does not work, continue to vary the adjustment until the flame burns correctly. The pilot should never blow out unless the outside air feed is too large. You can try blocking it a small amount to see if the smaller amount of outside air corrects the problem.
May 16, 2014 | Home
I see to have too much gas pressure after converting my Neptune dryer from natural gas to LP
you should not try to adjust the flame. LP burns more yellow that NG. The gas pressure automatically regulates the airflow based on the dynamic pressure that goes through the burner chamber. If your flame is roaring and pushing forward, everything is Okay, if it is a "Lazy" and falling flame, you have a blockage of the airflow - venting system
Mar 03, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Why can't I get rid of the yellow flame in my gas grill? I've replaced every component - propane tank, valve, venturi tube, burner, regulator etc. Still...the flame burns yellow and creates soot.
You have the wrong orfices in the gas manifold...they are too big and they are allowing too much gas out...if you are running LP gas and you have natural gas orfices it will do that...that is what I think your problem is...
heatman101
Aug 13, 2010 | Thermos Gas Grill 4617222
How do i change from lp gas to natural gas on wall oven
First thing you will need to do is find out from the manufacturer of the oven if there is a conversion kit available and if the appliance is convertable. If there is then you can order the kit and follow the installation instructions. Also check the back of the oven for an envelope that may contain the gas orfice replacement heads to convert the appliance to natural gas. If you find the replacement orfice then you will need to remove the lp orfice from the burner and install the natural one. Then the appliance gas regulator will need to have the pressure adjusted lower for natural gas. There is usually a removable cap on top of the regulator on the oven. When you remove this cap there is usually a small metal ring that you can remove and flip over. It will say "nat" on one side and "lp" on the other. You will need to turn this ring over and re-insert so it displays "nat". This will change the gas pressure from 13 inches W.C. to 4 inches W.C. Some appliances only require the orfice change and no regulator adjustment but make sure that is the case with your oven because if you feed 13 inches W.C. pressure to a burner with a natural gas orfice...YOU WILL GET A HUGE BURNER FLAME AND MAY BURN/FLASH YOURSELF...So use extreme caution when converting a gas appliance. And if the oven has a pilot you will need to adjust the pilot pressure or change it's orfice if it has one. If it is electronic ignition no adjustment to that will be needed. Also unplug the electrical power the the unit while working on it.
Oct 11, 2009 | Ovens
Poor burner flame
You have to adjust the air flow shutter on the burner tubes.
Jul 04, 2009 | Tappan MGF500PBW Gas Kitchen Range
OVEN FLAME TOO HIGH
HI, To adjust the size of the flame, turn the orfice clockwise to make it smaller. you can also try and adjust the air shuttle on the burner.
Are you trying to change from natural to LP?
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
Yellow flame
lp burners dirty.clean out the orfice and burner and this should solve your problem.
Dec 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Empire DV-215 Direct Vent Natural Gas Heater Logo
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
