Question about Miele Washing Machines
Miele W865 Washer ,Machine makes a noise and 'rinses' light keeps flashing ,keeps getting stuck at this point on cycle, help !!!
Posted on Jul 08, 2008
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
Miele w865 - door won't open after completed wash cycle
the solenoid sounds like it is defective on the door lock or the plug has fallen out of the door lock. if you remove the sealing ring clip which holds the door seal in place and pull back the seal you can reach inside the unit and make sure the plug is in place. check also there is power to the plug
hope this helps. if all else fails call the Miele service centre in your area and they will be able to help
May 08, 2010 | Miele W865 Front Load Washer
Check drain keeps flashing and machine wont drain even though drain is not blocked. I have removed and cleaned out debris in the drain filter but the problem persists.
You need to check fault is not upstream from the filter/ is it the pump? thats jammed due to sock or coin also check hoses leading to the filter are clear..
Nov 17, 2009 | Miele W865 Front Load Washer
Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Nov 03, 2008 | Miele W865 Front Load Washer
Door Seal on Miele W865
no he is right, there are 3 bolts around the seal, remove/unscrew them, pull front cover and the door will swing open.
loosen the wired coupling around the seal that holds in place and pull seal off.
Now u are ready to put your new seal back on. These is the hardest part.
good luck
Oct 22, 2007 | Miele W865 Front Load Washer
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
534 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
