Question about Whirlpool DU930PWS Built-in Dishwasher
The dish washer will not drain? The drain is not plugged.How do I get to the pump.
    President:
  • 2,468 Answers
Remove the toe kick panel below the door there are 2 or 4 screws holding this panel,then to remove the pump you will need to tilt the machine upward to get enough room to remove pump whi9ch will require the water and electrical supply connections be removed
Posted on Jan 01, 2011
3 Suggested Answers
  • 22 Answers
SOURCE: bosch dish washer SGS56E02GB
anti flood device has been activated, this means you have water in the base of appliance. most likely a leak, or if you have been using 3 in 1 tablets, and rinse aid this will over foam appliance and foams leaks into base.. try tipping d/w back to let water out of base..then try d/w again... if anti flood activates again...call an engineer.. ps check big nut that secures salt container to base of d/w, it can come loose which will cause water to leak into base ally
Posted on Jul 02, 2007
localwonder
  • 6784 Answers
SOURCE: dish washer wont drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Aug 26, 2009
Model 665.13929kq11. Why isn't it draining completely?
Dishwasher is draining slowly , and not completely ... - iFixit
https://www.ifixit.com/.../Dishwasher+is+draining+slowly+,+and+no...
iFixitJun 26, 2014 - I have a kenmore dishwasher (about three years old) ! ... with a solid plug in the drain tube for situations where a dishwasher isn't connected.
My Kenmore Dishwasher Won't Drain and is Leaking- How ...
? 5:35
https://www.youtube.com/watch?v=u7uaA2NZKl0
Nov 14, 2011 - Uploaded by mkbrennan13
This is a video to help someone fix their dishwasher. It's a How to fix your dishwasher that won't drain. If your dishwasher isn't draining and ...
How to fix drain problem with kenmore dish washer - YouTube
? 6:46
https://www.youtube.com/watch?v=ZMPXn6XgRkk
Aug 16, 2010 - Uploaded by itdatanow
Kenmore dishwasher would not drain. ... How to fix drainproblem with kenmore dish washer ... Is Your Dishwasher DrainInstalled Properly?
Dec 12, 2015 | Kenmore Dishwashers
What causes the dishwasher not to drain?
its usually a plugged drain from the dish washer to the garbage disposal i would disconnect hose at disposal end and let it hang down on floor into drain pan if it drains all the water from dishwasher it is the pump if it does not drain its a plugged line try to blow threw it and loosen up clog
Aug 16, 2014 | Siemens Computers & Internet
Siemens sn26m290
Could be that the pump is plugged or the water level switch is stuck. Check to see if the leveling switch moves freely by lifting it up and down a few times, then try the wash cycle again. Did you happen to wash dishes without rising them first, rice is bad for dish washers. Rice gets plugged in the diaphragm which is located in the drain line. You may have to remove the drain line fitting and clear debris which is lodged in the fitting.
May 11, 2013 | Dishwashers
Dish washer not emptying
put your model # into a google search and choose a place that has parts and look up your drain pump. you probably have either a clogged drain hose, not likely, or a bad pump.
May 13, 2012 | Dishwashers
SMEG DWI612C WON'T PUMP WATER OUT
even if the pump is running does not mean the impeller shaft is turning, You could unplug the machine and disconnect the washer and pull out and drop the hose to see if water will drain when you lower the hose to about 8 inch's does it run out freely? if not check for a plugged water pump or water pump hose if the water flows freely you will need to drain the washer if it's on rollers roll it out side to allow the water to drain out the machine from the porch. while it is draining check the hose that the washer connects to see if you see any plug in the pipe. put the sink drain plugs in and fill half way with water put a bucket under the sink after filling the water to half full pull the stopper out of the sink that connects to the dish washer. Hold your hand on the hole of the connection to the sing watch to see if the drain allows the water to flow. If it flows freely you can assume that the water pump is bad. If thats the case it's best find someone to replace the unit the pump can be replaced but you need tools to do so and you did not state if you had any. thanks for using fix-ya.
Apr 18, 2010 | Smeg 18 in. DWF409WH Slim-Line...
Does not pump water. Leaves dishes soappy
We really need your model number to help you properly. In the mean time you can check you sink connection and air gap for obstructions. Usually the cover just pulls up and off then you unscrew the cap to expose the drain tube for the dishwasher. More often than not if the unit fills and washes but leave soap on the dishes a clogged drain line is the problem. You may have to run something down the drain tube to clear it. Usually you will see the obstruction when you remove the cap. There is a remote possibility if it drains into a garbage disposal that food particles have clogged the drain outlet inside the garbage disposal. Hope this resolves your problems. Cheers!
Sep 20, 2009 | GE 15" Laundry Pedestal for Horizontal...
Dish washer not draining
Try following:
  1. Check sink drain and drain hose for restrictions
  2. Unjam the motor
  3. Unjam the pump
  4. Check the drain valve
  5. Check the drive belt
  6. Test the timer motor
  7. If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
pls rate my suggestion...
Jun 24, 2009 | Westinghouse Dishwashers
Dish washer wont drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Feb 02, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Washer making a weird noise
I didn't get to answer this but It makes "cents" to me.
Sep 09, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Jul 24, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Whirlpool DU930PWS Built-in Dishwasher Logo
148 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
