Question about Linksys RangePlus WRT100 Wireless Router
WRT120N---I keep having to disconnect my linksys, unplug all 3 wires on the back of the router, wait 30 sec...reconnect the router...try to get online...when it works then reconnect the linksys....what am i doing wrong???
    Scholar:
  • 124 Answers
Please disconnect and internet link and try to access the the Linsys WRT100 management page and see the logs why the router is loosing the connection. If you dont get anything then it might be some issue on the device. A reset may solve your issue.
Please be aware the if u reset the wireless Router you will loose all your configuration and you have to reconfigure the wireless Router.
Please press the tiny black button at the back/beneath of the wireless Router and keep pressing for 2 minutes. The sys light will start blinking slowly and then rapidly. then release the button and wait for 2 minutes for the device to boot up with factory default settings.
Once you are done you can connect to 192.168.1.1 ip address and it will open the your Linksys Router management web page where you can reconfigure your wireless router again.
Hope this will fix the issue.
Best Regards
Posted on Jan 01, 2011
Unbrick router e2500
If you installed dd-wrt for your new router firmware it's possible you installed the wrong firmware. In most cases, it's permanently bricked. If not, you can try the 30/30/30 method to reset the router to its original factory settings. That is
1. Unplug the router and press the reset button for 30 secs
2 plug in the router and press the reset button for 30 secs
3 unplug the router again and press the reset button for 30 secs
During the entire process keep the reset button depressed. It takes some good hand coordination. 20/20/20 always worked for me for all the linksys routers I've owned over the years.
Jul 06, 2014 | Linksys Computers & Internet
Linksys E2000 keeps disconnecting
Disconnect the power from the linksys for about 30 seconds then plug it back and see if it stops dropping. Most times the dropping occurs if you turn the modem and router off at night then when you turn them back on the router boots up faster than the modem and that will cause it to drop. Power outages also will cause the problem if the router boots up before the modem.
If unplugging the router and waiting 30 seconds does not solve it then unplug both the modem and the router. Then plug the modem back in and let it boot up for a minute or two, then plug the router in and let it boot up.
Jun 05, 2012 | Cisco Linksys E2000 Advanced WirelessN...
I can't connect to the internet w/ my new laptop. I can't find my security key to hook up.
This article documents a known issue with resetting a Linksys WRT120N to its factory default settings.
Symptom: Holding down the reset button on the back of the router does not reset the settings.
1) Download the latest firmware from Linksys (link below).
http://homesupport.cisco.com/en-us/wireless/lbc/WRT120N
2) Unplug the router, hold the reset button, and plug in the router while still holding the reset button.
3) Open Internet Explorer, go to http://192.168.1.1
4) Use the "Browse" button to locate the firmware file downloaded from Linksys.
5) Once the update is complete, unplug the router and plug it back in.
6) Hold the reset button on the back of the router for about 30 seconds, a light will indicate when it resets.
7) Allow the router to reset for 1-2 minutes.
8) Open Internet Explorer, go to http://192.168.1.1
9) Enter "admin" for the username and "admin" for the password (without quotes).
Your router should now be reset to the factory defaults!
Nov 04, 2011 | Linksys WRT120N Router
Linksys wireless g wrt54g router connectivity drop: our linksys wireless router disconnects about every day. We are forced to unplug the router, wait 30 seconds, and then reconnect, which brings the...
Couple actually... 1. See if you can reset the router once and set it up once again. 2. Check if you can upgrade the firmware of the router. 3. To ensure this is not a wireless issue, go wired and check if the issue continues4. Also connect to the modem directly , bypassing the router to make sure its not the modem thats actually causing the trouble.
Sep 26, 2011 | Linksys Wireless-G WRT54G Router
I'm trying to to use the wifi but it is asking for a wpa password and i can't find the wpa password
Perform a Linksys reset
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
Router setup
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 31, 2011 | Cisco - Linksys Wireless-n Home Router -...
When initial set up completed both wired and wireless say connected but won't open up webpages. Could the firewall effect connection to the internet.
WRT120N router has issues with the firmware. make sure that your computer is able to go on line when connected directly to the modem. If that is working then download the new firmware of the router from www.linksys.com/download . connect the modem and computer to the router and open the set up page of the router. upgrade the firmware of the router.
After upgrading firmware. Reset the router for 30 seconds. wait for 1 minute. Unplug the power and plug it back in. wait for 1 minute and reconfigure the router.
Click here for more information about the routers
Mar 18, 2010 | Linksys WRT120N Router
WRT54G keeps disconnecting itself, requires disconnecting/reconnecting power and running setup disk again to reconnect. System info: 12 mb/s cable broadband ISP, Motorola SB5105 cable modem, WRT54G...
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Mar 04, 2010 | Linksys Wireless-G WRT54G Router
My linksys wrt120n will not reconize the road runner modem when the ethernet cable is hooked up to it
This router has lot of issues with the firmware. Firmware is the software of the router. First thing you need to do is upgrade the firmware of the router.
If you connect your computer directly to the modem it will go online. Download the firmware of the router from the web site www.linksys.com/download .
Now connect the computer and the modem to the router. open the router set up page. upgrade the firmware. After upgrading the firmware, reset the router for 30 seconds . Unplug the power and plug it back in. wait for 1 minute and reconfigure the router.
Click here for more information about the router and router set up
Feb 22, 2010 | Linksys WRT120N Router
My wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
Trying to connect an old WRT54GLWireless-G to new computer&laptop
what i would do is go to the back of the router and find the pin hole that says reset push that in with a small item and hold it down for 30-35 secs and release dont unplug the router just let it sit till all the lights come back on now it should be back to factory settings now i asume you are runing wireless if so the ssid would be linksys you can go and change all of the settings by opening an internet browser and going to 192.168.1.1  the username is admin and the password is eather going to be admin or password  after doing this make sure your eathernet cable from your cable or dsl modem is pluged into the port on the back of the router labeled internet and if you are runing any of the computers on eathernet and not wireless make sure there pluged into 1-4 that should fix your problem
Mar 27, 2009 | Linksys Wireless-G WRT54G Router
Linksys RangePlus WRT100 Wireless Router Logo
315 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
