Question about GE Energy Star WCVH6260F Front Load Washer
The drive belt broke and i cant get the new one on.
    President:
  • 2,468 Answers
They are tough to put on but start by putting the new belt on the motor pulley first then with gloves on so as not to pinch your fingers start the belt on the larger pulley on the drum and just work it on by turning the pulley as you go,it will go on, but it will be very tight when its finally on both pulleys
Posted on Jan 01, 2011
I have a old lawn keeper edger with a briggs and stratton 2 hp engine. It has always run great but the belt came off and we cant figure out how to get it back on. Can anyone help with that?
If the belt just came off, it should be fairly easy to refit back on its pulleys. Use the largest pulley to assist in pulling the belt on by turning the pulley by hand. If the belt has broken, you may have to remove 1 of the drive shafts to slide the new belt over. I had a B and S powered mower which broke a belt and I had to strip off the end of the mower and unbolt the main drive shaft to slide the belt down. took me about an hour and a half. Glad they don't break too often. Ive heard of others who unbolt the motor and disconnect the clutch drive to fit a new belt. have a good look at the unit to see whats easiest.
Mar 22, 2017 | HP Garden
2001 eclipse serpetine belt broke put new ones on now car turns over but won't start.
2001 GT Eclipse Spyder..cranked this morning, both drive belts broke, harmonic balancer came apart..replaced balancer, belts, now it won't fire. I did find a piece of one of the drive belts intertwined in the timing belt. Thing is absolutely not getting any fire.
Sep 23, 2015 | Cars & Trucks
Johndeere gx75 drive belt diagram
I broke a drive belt on my gx75 and need to know proper routing and installation for new one AmanStino Ultra Slim Lightweight Smart shell Stand Cover with Auto Wake...
Jun 15, 2012 | Cars & Trucks
I need a belt diagram because mine broke and i cant figure out how the new one goes on
Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
Accessory Drive Belt 3.0L (4V)
Accessory - SHO
Water Pump - 3.4L SHO
Mar 17, 2011 | 1996 Ford Taurus
Belt broke that drives the water pump and alternator on my 88 plymouth reliant. another belt in the way, and cant figure out how to get the new belt on.
You can loosen the alternator that should releive the tension on the belt.
When you tighten it again make sure you can only turn the belt 90 degrees then you know you have the right tension.
Jul 11, 2009 | 1988 Plymouth Reliant
The drive belt broke on my bread machine. where can i find a replacement. this seems to be a quite common problem with this particular brand
if the belt broke there had to be a reason . most of the time you have a bad bushing on the mixer paddle or the main drive wheel . thats why you cant fine one . there sllways some other thing thats bad , and the second one breaks too
Jan 19, 2009 | Kitchen Appliances - Others
Drive belt tensioner pulley
the tensioner pulley is a small plastic or metal wheel about 3 inches big ...center of engine....
Dec 11, 2008 | 2006 Hyundai Sonata
Vacuum too hard to push
If it is new, you can take it in for warranty repair. Is the self propelled turned on? Cable may have broke, or have a bad drive belt.
May 30, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Car just stopped
Have your Crankshaft position sensor checked. Or possibly the fuel pump
May 15, 2008 | 2004 Dodge Stratus
GE Energy Star WCVH6260F Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
