Question about JBL P80.2 Car Audio Amplifier
Help??? I have a four channel 4 ohm amp that I need to run a single 12'' dual 2 ohm sub! I have no idea how to wire it?
  • 109 Answers
It's not really made to run a dual 2ohm sub. What you can do though is wire the sub like this:
we'll call you subs voice coil A and B. Wire it like this A's(+) to (+) on amp; then A's (-) to B's (+), then B's (-) to (-) on the amp. This is known as series / parallel wiring it will effectively make your amp see a 4ohm mono load.
What brand and model of amp do you have?
Posted on Aug 19, 2008
2 ohm amp to 2 10 inch dual coil 4 ohm subs how does it need to be wired
Is the amp a single channel? If so, the only way to connect the subs (without overloading the 2 ohm stable amp) is to wire each sub's voice coils in parallel (2 ohm) and then connecting the subs in series (4 ohms). If the amp is two channel, the subs can have their voice coils connected in parallel (as before) and then each sub connected to its own channel.
Apr 08, 2016 | Dual Car Audio & Video
Do you bridge a 850.4 four channel amp when it is 2 ohm stable and ur subs are wired up as series/ parallel and there 2 ohm dual voice coil speakers
If you wire 2 ohm dvc speaker parallel that would give you a 1 ohm load. If your amp is only 2 ohm stable that would not work. You would have to wire the speaker in series giving you a 4 ohm load. Then you can bridge the 4 channels into 2 with each speaker running at 4 ohms.
If you want to run a 2 ohm load use all 4 channels on amp and speakers. No need to bridge.
For 2 ohm DVC:
Parallel = connect both + and - together. = 1 ohm
Series = connect + from 1 channel to - from the other channel. = 4 ohm.
Jul 06, 2014 | Car Audio & Video
I have 4 wires what do they do I no to of thim will go to my Kicier ame I Ddont no were the other to go
OK, I am assuming that you have 4 wires coming from the subwoofer itself. Your subwoofer has dual voice coils, this means there are two positives and two negatives. Look closely at the posts on the subwoofer and you can tell. These wires will go to your amp, all four of them. Here's the tricky part. You need to know if your amp is a monoblock (single channel) or two channel amp. Also, what ohms is it stable at (4, 2, or 1). If you have a monoblock stable at one ohm, take both positives from the sub and put to the positive of speaker output on the amp. Then put both negatives from the sub to the negative speaker output of the amp. If your sub is dual 4 ohm voice coils, this will give you a 2 ohm load. If you have a dual 2 ohm voice coil sub, this will give you a 1 ohm load. If you amp is 2 channel, just hook one set of positive and negative to one channel and the other set to the other channel. Hope this helps
Aug 28, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a 12 inch audiobahn 550 rms 4 ohm coil ported box and a dual box with 12 inch subs they say 550 max wattas a piece thats it waht amp do i need to get atleast 80% of my power in bass
Get a 1200 watt 4 channel amp that's 2 ohm stable. Bridge 2 channels into the single 550W rms audiobahn. Use the other channels for each side of the dual box. Turn the LPF or Low Pass Filter on and vibrate down the road.
Sep 25, 2010 | Car Audio & Video
Hello, need to know how i should wire a single 14" sub spk to my ST4-720 ??
havent heard of too many 14" speakers... but it all depends on what ohm the speaker is. single 4 ohm- bridge it on one set of channels. left + right- . if its a dual 4 ohm i wouldnt reccomend using it at all. you could technically bridge each coil on each set of channels. but it may not sound right. kinda hard to set the gains and match them. dual 2 ohm- run the sub stereo. one coil to one channel, the other coil to the other channel. single 2 ohm. dont use it unless you get another sub like what you have. then run it stereo. one sub to one channel. the other sub to the other channel.
Dec 27, 2009 | Sony ST4-720 SPL 4-Channel Power Amplifier...
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
http://www.bcae1.com/spkrmlti.htm
Nov 20, 2009 | Hifonics BXi 2006D Mono Block Amplifier...
Is it a good idea
Based on your description and on the idea of a single amp, then your plan of hooking up both the subwoofers in series (to get 8 ohms) would be the safest as against running the subs in parallel (2 ohms). This way the sub amp would not be overly loaded, you can compensate the slight loss in power by strategically positioning the 2 subs. A friendly reminder, pls observe polarity when hooking the sub speakers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Car Audio & Video
Bridging 800a4
That all depends upon whether or not the sub you are running has dual voice coils or just a single voice coil. The 800a4 is a four channel amp; thus the only way you can bridge it will be 3 channel or 2 channel. If you are running a dual voice coil sub then you can wire the amp two channel and get 400 watts x 2 @ 4 ohms. Make sure that you sub can handle this kind of power though.
Here are the specs:
4 x 100 @ 4 ohms (13.8V - <0.05% THD)
4 x 200 @ 2 ohms (13.8V - <0.10% THD)
2 x 400 @ 4 ohms bridged (13.8V - <0.10% THD)
Fuse: External 60A
Manufactured in 1999 - 2001
Jun 18, 2008 | Rockford Fosgate Punch 800a4 Car Audio...
Speaker connections
This is a single channel amp that puts out about the same power at 4 Ohms or 2 Ohms. If you have two 4 Ohm single voice coil subs, then wire them parallel (both pos and both neg) to achieve 2 ohms. If you have two dual 4 Ohm voive coils, you want to do a series - parallel config to get to 4 Ohms (voice coils in series, then parallel the subs). Same with DVC 2 Ohm subs, series parallel = 2 Ohms. Do NOT go below two Ohms. You will blow the amp (actually, it'll do 1.5 Ohms). If you happen to have 2 Ohm single voice coil subs (not as likely) run them in series. Most amps will put out about twice as much power at 2 Ohms vs. 4, but this amp is designed to put out about the same. Hope this helps!
Feb 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
JBL P80.2 Car Audio Amplifier Logo
121 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
