Question about Dryers
My dryer runs and sounds fine but has no heat. there is no pilot. What do i need to replace?
    President:
  • 2,468 Answers
It doesn't have a pilot light,it has an igniter that can open and then won't glow to ignite the gas,.or it can be the thermal safety fuse or the heat cycling thermostat on the blower housing thats open or any of the thermostats on the burner tube bad,the flame sensor on this tube also,or even the gas valve coils on the gas valve body could be bad,sounds more like the thermal fuse if you get no ignition at all
Posted on Jan 01, 2011
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Here is a video to walk you thru the diagnosing and repair for your dryer.
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
My dryer is a ultimate care heavy duty super capacity runs fine but it wont heat up so it don't dry. Does it have a pilot or something i need to replace?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 20, 2011 | Whirlpool Dryers
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Dryer is running, but no heat
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | GE Profile Harmony DPGT750EC Electric...
The dryer was heating fine earlier, but now is not heating at all. Is there a pilot light on my dryer that may have been blown out?
Hi, With the dryer running, look into the small front panel and see if the ignitor is glowing at all. If the ignitor glows but there is no flame, the coils on the gas valve are bad. If the ignitor does not glow, you will need to (with the dryer unplugged) check continuity on the thermostats and the flame sensor on the side of the burner.
If any of these parts show no continuity, that part will need changed.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 28, 2009 | Dryers
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
Runs but does not heat
Try removing the jets and clean them out. the pilot may be off center and in need of calibration.
Jul 02, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
