Question about Tomtom GO GPS Receiver
The Tomtom XXL was unplugged from the cigarette lighter overnight. What do I do to recharge it?
  • ruther1 Jan 03, 2011
    I plugged in the device to the cigarette lighter; started the ignition but the screen is black. Can you tell me why?
  • 457 Answers
The device can be run from the lighter plug without being charged first. The obvious answer is: plug in the device again; when the car is key is in and electricity switched on, it should charge again.
Most Tomtom devices also come with a standard USB cable or charge cradle with non-standard connector on device end (but USB on the other). It plugs in a PC for use with the Tomtom HOME software and also for charging.
Posted on Jan 01, 2011
Testimonial: "I am a complete novice and do appreciate your help!"
  • MiB8888 Jan 05, 2011
    May have several causes:
    1. Battery dead due to too cool storage (LiPo batteries die when stored well under 0°C / 30°F for some time).
    2. Cable, plug into device or plug into lighter plug broken (last one is very common).
    3. Charger circuit fried.
    4. Fuse of cigarette lighter blown (happened to me once).
    Check any of 1, 2, and 4 first, then replace charger (3).
    I assume, you switched on the device using the button on the top...?
Tomtom XLL will not hold a charge
I suggest you go to your nearest car electrical expert to check your car if there is problem with your car electrical connections..
Dec 19, 2013 | Tomtom XXL 550 Car GPS Receiver
Can i use tomtom in 1996 ford mondeo cigarette lighter
So long as it is a 12 volt negative ground system then yes. Plug ins are designed for cigarrette lighters in cars.
Nov 24, 2013 | Tomtom GPS
Can the Tomtom recharge wheh the car is not in use - eg in the garage
No, then tom tom cannot recharge when the car is not on. You need to turn on the car before your tom tom can charge. The battery gets to charge the tom tom when in use. Once the car is turned off the gps will not charge. You can try out a practical by turning off your car and plugging the gps to see if it will work. Or the cigarette lighter, does it work when the car is turned off. Since the cigarette lighter does not turn on when the car is off, then it means it gps cannot charge once the car is turned off.
Hope this information helped you!
Jan 10, 2011 | GPS
How do i know my xxl 540s battery charge full?
To know if your tomtom is fully charged. Unplug the tomtom from the power source and you will see the battery meter, if it is full or not, because while it is charging, it is the power source that is working so the battery signal will not come up. Unplug it and you will see the battery meter.
Hope this was able to solve the problem.
Dec 21, 2010 | Tomtom XXL 540S GPS Receiver
2000Silverado 5.3 Battery light is on in the morning, volts read 11 or 12 normaly read 14,after running a while it goes to 14, twice it feel below 5 volts battey went dead, got new battery,gheck grounds,...
Something is draining your battery overnight and once you start running it, it recharges your battery. If you have anything plugged into your cigarette lighter, unplug them. Unplug anything that you can, like if you have an amplifier for your stereo or anything else. Tonight unhook your negative terminal, and then hook it up in the morning and if it is ok, then you know that is definitely your problem.
Dec 03, 2010 | Chevrolet Silverado 1500 Cars & Trucks
My cigarette lighter will not charge my TomTom
The plugs which are used with car lighters are often very poor; compare the firmness of the seating of the lighter with your accessory plug. The latter are often too loose to make decent contact.
Also, that plug is equipped with a fuse; unscrew the plug body and check the fuse.
I also recall someone having a failed plug on the Tomtom itself; it may be a weak point.
Jul 08, 2010 | Tomtom ONE GPS Receiver
Just got my TTone, confused about when to use the charger
To avoid an eventual loss of power while you are driving and the subsequent unsafe fumbling with the machine, you can plug the TT in the cigarette lighter during your ride. This will supply power to the GPS and recharge the battery.
Alternatively, before going on a trip plug the TT in a USB port of a computer and it will recharge the battery. With a fully charged battery and the car power adapter/battery charger you will not run out of power.
Dec 31, 2009 | Tomtom ONE 130 GPS Receiver
Cigarette lighter adaptor becoming very warm in use
the lighter receptacle is dirty and needs cleaning
Mar 23, 2009 | Tomtom ONE XLS Car GPS Receiver
Will not turn on
do you plug it into the cigarette lighter or is it installed (wired) behind the cigarette lighter. If so and you happen to plug something into the lighter you run the risk of shorting out our friend TomTom (I did it twice)
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO GPS Receiver Logo
151 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
