Question about Hitachi 42HDS69 42 in. Plasma Television
The input and menu functions don't work, but all other functions do work from both the remote and from the buttons on the TV itself. Neither the remote nor the buttons on the TV will activate the menu or input functions.
    Top Expert:
  • Hitachi Master
  • 74,383 Answers
Hello
Check the input connections first. Completely insert connection codes to the side panel jacks. If you do not, played back picture as well as selection will be abnormal.
Connect an external source to one of the INPUT terminals, and then press the INPUTS button to show the INPUT menu. Use the CURSOR PAD UP or DOWN to select the input of your choice. And then press the SELECT button or the CURSOR PAD RIGHT to confirm your choice.
Without any inpu signal, the input selection cannot be done. All the input chords must be conneted firmly and fully inserted to their respective sockets. OK
Posted on Jan 02, 2011
The input control button not working
Usually there is a input button on the TV itself.
Oct 16, 2012 | Toshiba Ct-90302 Remote Control
TV Doesn't Function: Can turn on, but no menu or input recognition
the set like all has a hard reset which requires a four digit number code and the original Mitsubishi remote---sets almost everything in the set back to original except convergence.
also, don't buy any TV or electronics on CL as people dump their problems on someone else..
Aug 31, 2012 | Mitsubishi WS-65313 65" Rear Projection...
I want to use the RCA connections but I don't have the remote
To connect and select the input to TV to AV, you must have its remote control, as there is no Menu button at the front panel of this TV, to get into its menu option, and to select AV function.
Jul 04, 2012 | Symphonic ST427FF TV
I cant figure out how to put the tv on video 1
With the remote in TV mode, the input button on the remote should change the source (TV, AV1, etc. depending on the TV).
If the input button doesn't work, try a different code for your TV manufacturer. A code that controls the basic functions of the remote may not control the full set of functions of the TV. For some TVs, you can change the source from within the Menu. (It depends on the TV. I didn't notice if there was a Menu button that will open the TV menu on the RCA RCU600M.)
If none of the codes work, check if your TV has a Source or Input button on the unit. See if that button works.
If you have a different remote, please indicate the model.
I hope this helps.
Oct 13, 2011 | RCA RCU600M Remote Control
Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
Sep 15, 2011 | Sanyo AVM-3259S TV
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
My tv turns on an off, and the picture and sound works fine. The problem I am having, is that no matter what button you push on the remote, or the tv itself, it just brings up the input. You could hit...
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual functions controls board that have like buttons POWER,Channels + -,Volume + -,MENU.This manual functions controls board it is shorted.
May 21, 2011 | Element Electronics ELCHW261 26 in. TV
I do not have a remote for the tv but I am hooked up to fios cable system which has its own remote. All things seem to function but I can't change input. All I get when I hit the input button on fios...
The Fios remote work only on the Fios box only as u found that out.U want to control the tv itself,u must have the tv original remote as u used as for like the tv Input button and the tv and other functions of the tv itself.Try website like Remotes.com to buy the tv original remote.
May 09, 2011 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Cant get the remote to work for menu options just started setting it up already programed to my direct tv remote now nothing is working or either remote t.v or direct tv remote
To diagnose a remote control problem follow these steps.
1) unplug the TV power cord, count to five and plug it back in. (reboot)
2) try to power on with ORIGINAL MANUFACTURER remote.
if that works- your TV and original remote are fine.
if that does not work:
4) try to power on with buttons on the TV itself- if it works- check your remote batteries and try remote again.
Direct TV and Dish Network remotes will ONLY operate SIMPLE function of your TV such as power, volume, input.
They will NOT access your TV menu.
Apr 12, 2011 | Televison & Video
TOSHIBA 35 TV 35A44
don`t know if this will work for yours but I have heard of menu coming up all by itself randomly and the fix was to remove the batteries from the cable boxes remote and the tv`s remote, partially stuck on buttons were the cause, replaced the remote end of problem, hope this helps on yours.
Nov 29, 2007 | Toshiba 35A44 35" TV
Hitachi 42HDS69 42 in. Plasma Television Logo
94 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
