Question about Grohe Satin Nickel Soap Dispenser...
The soap dispenser leaks from the top housing above the cabinet and everything is tight. Does it need replaced or is there a fix.
  • 43,501 Answers
Unfortunately they crack after use and that is not economically fixable...
The best thing to do is to just buy a new one and replace the whole unit..
heatman101
Posted on Jan 01, 2011
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water leaking out of soap dispenser?
Mar 17, 2013 | Washing Machines
Simpson front loader washer leaking from front soap drawer on the spin and rinse cycle when filling
Mar 10, 2013 | Washing Machines
Doesn`t dispense soap right. soap left in dispensor
Hi
Try and disassemble the dispenser & check the wiring to the dispenser housing--
1. Disassemble the top plate assembly(Unscrew 2 screws on the back of the top plate).
2. Pull out the drawer.
3. Push out the DISPENSER ASSEMBLY after unscrew 2 screws.
4. Unscrew the nut at the lower part of the dispenser.
5. Disassemble the 4 connectors from the valves--
Wire Color
Blue Housing (OR-BK)
White Housing (WH-BK)
Blue Housing (GY-BK)
Red Housing (BL-BK)
6. Unscrew 2 screws from the back of the cabinet.
Hope this helps... Please post back if you need more information.
Daniel
Feb 17, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM WM2277HW Problem: cannot pull open the soap/bleach/softner dispenser drawer. Have a solution?
Hi
Wire Color
Red Housing (BL-BK)
Daniel
Jan 26, 2011 | LG WM-2277HW Front Load Washer
My dish washer soap does not dissolve, whether or not I put the tablet or the pillow into the soap dispenser. Is it the soap dispenser door? Would hard water buildup create low water pressure so the soap...
The most likely causes are the you are using a tablet in a gel coating but putting the tablets into the dispenser drawer when the dispencer drawer is damp, thus causing the tablet to stick inside the housing; or, if the dispenser drawer is releasing the tablet into the bottom of the cabinet then I would say you have a problem with your water heater. In which case you would need an enginner to come and replace the heater.
Hope this is of help
Jan 25, 2011 | Maytag MDB7100AWB Dishwasher
Have a intermittent leak in the soap dispensing area in top left area above the front loader sears kenmore # 417.29052991. looking for service manual to guide me on getting into that area for repairing.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 16, 2009 | Kenmore Washing Machines
Bottle under Grohe soap dispenser leaks down to cabinet
Pull the dispenser out the top and have someone hold the trim above the counter while you tighen the bottle down below.
But the real problem is the retaiher nut which hold the dispenser in place is loose. Remove the bottle underneath ( it unthreads) and tighten the nut that you see just above the bottle. This can be a tight spot and you may need a basin wrench.
Please rate this response and Good Luck, Phil
Dec 27, 2008 | Grohe Satin Nickel Soap Dispenser...
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
Grohe Satin Nickel Soap Dispenser... Logo
288 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
