Question about Sanyo 42 in. LCD TV
We left for a short trip and when we came home our brand new sanyo flat screen tv spekers sound blown. Could it be because it got really cold in my house? Are the speakers blown?
  • Sanyo Master
  • 8,457 Answers
Yes,could be did it drop to 40 to 30 in your house?Tries tv unplug,replug back about and hour later.Now,the tv is resetting back to the factory setting.Go into the tv Menu go to AUDIO SETTING,going to resetting.These process,will help have audio again.
Posted on Jan 01, 2011
    Brigadier General:
  • 8,909 Answers
The speakers can only be blown if the TV was at a high volume for a long time and I would expect to hear something. Have you tried running through the menu and seeing if something has been overlooked?
My screen is pink with no image
Yes, it's the lamp. Order one from your local electronics repair shop. Or toss your Sanyo TV in the garbage and buy something new
Jan 18, 2015 | Sanyo DP32649 31.5 in. TV
My Sanyo Flat screen TV is dead. No sound and pictures
Could be the power supply board. If there are no lights at all This may be the issue. For about 50-75 bucks you should be able to
buy a new one. If you are handy and can solder is is most likely
blown capacitor "caps". Very cheap fix a couple of bucks, but be careful a capacitor disharge could knock you on your can or in a really bad situation kill. Not kidding. First always look for a reset button or blown fuse.
Nov 23, 2014 | Sanyo Televison & Video
Phillips 42PFL3603D/27 wont turn on
Check the site linked below, and see whether it can help you. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Dec 04, 2012 | Philips 42PFL3603D/27 42 in. LCD TV
Sanyo 46
It sounds that the connections between T'Con board and panel have some loose contact. Re-seat all the flat cables and check. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 27, 2012 | Sanyo DP46848 LCD TV
Scratch on sanyo flat screen tv
The overlay or outer screen on any LCD or Plasma is bonded to and cannot be removed/replaced short of replacing the entire Panel or display unit which needless to say costs more than the set did when new.
If its an older projection set the outer clear screen may be available depending on brand and model number.
Apr 18, 2012 | Sanyo Televison & Video
Sanyo big screen tv stop working. First the sound kept going on and off then the tv would turn off by its self. Finally it went off and it wont go on.
open your TV unit check possible loose contact. check defective parts to the power supply shorted regulator, blown fuse, open resistor and leak capacitor replace same ratings.
Apr 12, 2011 | Sanyo Televison & Video
I have a Sanyo 42" LCD tv model DP42649. The
The problem i'm having is, when you turn the tv on it has a split screen with the left side shaken off a little bit. if you give it a tap on the left side it will flicker and the whole screen will come on.
Dec 29, 2010 | Sanyo 42 in. LCD TV
Is there a way to fix my sanyo 32in cracked screen #DP32648
You can have them repaired using a TV Repair guy but often it costs as much as a brand new LCD. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Jan 02, 2010 | Sanyo DP32648 32 in. LCD TV
Sound go,s on and off for only a short time . Tv is brand new just out of the box.
Go into the menu under Audio and make sure the SAP is turned off.
Nov 30, 2009 | Sanyo 42 in. LCD TV
Sanyo PLV-55WM1
Hi I read your problem with the Sanyo PLV-55wm1. It sounds to me like a power supply problem. Like most new electronics devices, they use a switched mode power supply (SMPS)to supply the voltages to the rest of the set. Many of them use a current feedback loop to sense a short in the circuits that it powers. I would check for a shorted diode in the high voltage section of the tv. If any one of the components is shorted around the high voltage circuit, The current control line will be zero forcing the regulator to shut down.
Mar 25, 2007 | Sanyo AVM-1909S TV
Sanyo  42 in. LCD TV Logo
510 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
