Question about Technics SA-TX50 Receiver
SA TX50 I have no sound coming from my front speakers. If I turn the volume up to the highest level I can hear muffled sound from the speaker.
Steve4trace on jul 8,2008
UNPLUG the receiver from the outlet. Take cover off. See the circuit board to the right of the dial (front facing U) behind the glass window. The bottom of those circuits are connected by pins that fit the other circuit board. Press them together or tie that corner safely to the back end using non-electrical wire (use poly-twine). When you do this you will not be able to put the cover back on. You will have to leave it exposed. If you like your receiver that much like I do - this is the solution I found. Put the receiver back where it is protected (from kids, juices, water, etc.) and enjoy your surroundsound again. You might have to do that to the other side. It worked for me. Use common sense when looking. Good luck.
Posted on Jan 24, 2010
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
Technics SA-1000 Volume Level low
Hook the speakers to the remote terminals on the back and switch the front speaker control to select the remote speakers. If you have audio, your main amp channel may have an issue....
Sep 18, 2017 | Audio Players & Recorders
No music coming from my left front speaker. I ran the level calibration and I can hear the pink noise coming loud and clear to that speaker. I have both front speakers set to the same level, but I only...
Looks like your volume control switch is not working on the left side, you can check it by tapping the knob on the volume control and sound will come out on left side.
The only way to get the sound again is to replace the volume control or pull out the volume control and open it up to clean the contacts in it.
Hope that helps you out!
Thanks for using Fixya!
Dec 12, 2010 | Onkyo TX-DS787 Receiver
Unit comes on ,work and shuts off. Comes on again ,work for a while and shuts off.
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Nov 09, 2010 | Technics SA-TX50 Receiver
I stopped having sound coming from the speakers. I checked and we are not on mute, and the volume is turned up high.
Make sure all your connections are tight and you have power to your speakers...Then go Start>Control Panel>Sound and Hardware>Sound, after you are in here make sure that your speakers are selected as default device.
Hope this helps, pls rate
Mar 19, 2010 | Proview Computers & Internet
Sound coming from speakers is very quite. must
check your manual for a quiet mode, or reset factory defaults. it might be stuck in "attenuator" mode, where sound is muffled, in case you're answering a phone.
Jan 23, 2010 | Onkyo Tx-sr507 A/V Receiver
I have an Aiwa cx-nma545 that I just hooked up to a Westinghouse SK-32h640g. The sound is very muffled. The sound is fine if I have it on cd or the radio but when on Aux Video I can barely here it.
On most TV's with speaker control there's a way to disable the TV's volume control effect on the level fed out to an external amplifier. Find it and disable it it or select FIXED for its level, or, while listening through the Aiwa, raise the TV's volume through its own remote and see if that affects what the Aiwa gets for volume.
Or, enable the TV's speakers but find the same interna lAudio setting and make it Fixed, but turn the TV volume down if you don't want to hear its speakers. That way, you could actually listen to the TV on its own speakers if you want, say, for casual watching of the Weather Channel or news, for example.
Nov 28, 2009 | Aiwa NSX-DS55 CD Shelf System
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
Open Questions:
See all Technics SA-TX50 Receiver Questions
262 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
