I have a Bang&Olufsen Beogram
I have a Bang&Olufsen Beogram RX which has been sitting in the attic most of it's life, as I've moved on to CD's like the rest of the universe. Now I am trying to hook it with my stereo sytem, but am not getting very far because, though power is on in the turntable, the platform will not spin. I recall, or think I do, that when setting it up after a move, etc., there was something I had to do to unlock something. I know I'm sounding vague, but I really can't remember for sure. I don't believe anything could be wrong with the belt. It did revolve a few years ago when I attempted to hook it up to my Bose. (However, I discovered at that time that I'd have to add a preamplifier. So I just bagged the idea. Now as I'm trying again,the turntable won't tun when we turn it on. Can you help? Corinne 570-259-6303
    Genius:
  • 1,011 Answers
Sir,
A belt-drive turntable is a work of art and a musical treasure. It provides listening pleasure that has yet to be fully realized by the compact disc and digital technology. Listen and compare with an open mind and you will believe.
Replace the Turntable belts....
thanks
good luck
don't forget to rate the solution
Posted on Jul 08, 2008
  • 2,296 Answers
I would still check the belt, rubber normally gets hard or soft depending on the temperature that it was expose to. You could also have to move the arm manually until engages the switch to activate the motor whenever you press the start/run button.
I'm working on one turntable as I type here, same condition with this one, in storage for a very long time.
Let me know if you require further assistance.
  • 4,234 Answers
You need to remove the platter and look underneath it. There should be a belt that at this point is probably goo. Remove all of the old belt and replace it. I don't have the size with me at the moment but it is likely to be a 23.6" belt. If you can post the exact model number, I'll look up in my belt cross reference book and post the exact size.
Dan
  • 487 Answers
Similar to most Beogram 1800, the RX 2 featured record sizing by weight. When Play was selected, the centre part of the platter would raise gently, with only just enough force to lift a 45RPM single. An LP would be too heavy to lift, so the mechanism would set itself to 45RPM and 18cm if the record lifted, 33RPM and 30cm if it did not. The speed control keys could then be used to override the choice for non-standard records. The parts could also detect if a record was not present, and prevent the turntable being activated
Just put lp on and it should work
  • eric bosman
    eric bosman Jul 08, 2008
    this should solve your problem and i wish you good luck with a beautiful piece of hifi tech
My bang and olufsen 7002 wont select the phono stage
The Phono/Aux input has a slider switch to the left of it to choose whether to make it a regular line-in jack or to utilize the phono stage. The ground terminal is just above the jacks. The Beogram 4002 likely has a muting circuit that's in effect when the tonearm is in the lift position, which would explain the lack of hum til the stylus lowered to the record.
May 19, 2015 | Bang and Olufsen Audio Players & Recorders
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
Bang & Olufsen BeoSound 2000 door doesn't open (disconnected)
Push the door to the left this normally engages the door to the mech.it is designed to detach if the door is jammed or too stiff to move.Cleaning of the guide rail and door carrier is usually the cure.this can only be done properly be removing the central cd clamper and control panel assy.
Dec 31, 2009 | Bang and Olufsen Audio Players & Recorders
I have a Bang & Olufsen Beocenter 9000 with a missing CD spindle
You might be able to get one from online parts shop CPC, they stock B & O parts. You can worry about if you can fit it when you've got one!
Dec 24, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Bang and Olufsen Turntable will not platter will not spin
Normally on the RX-2 there are only 3 transit screws but if they are stuck you might need to gently try to lift them while turning anti clockwise. You can do this with a Steel Ruler and yoiu may have to use a little bit of force as some people torque them down tight. As for manuals and service manuals - they are rare!
Oct 07, 2009 | Audio Players & Recorders
Where can I buy an optical reader for my cd player?
cd mech no longer available.try cleaning laser lens.try replacing 30tr6108 and30c2103 bc338 and33/16v
Feb 12, 2009 | Bang and Olufsen Audio Players & Recorders
Beogram 1800 wont play the record!!
possibly some kind of obstruction inside.
I had something similar with my turntable, and it had a dirt dauber nest inside it!
no kidding.
Dec 03, 2008 | Audio Players & Recorders
203 people viewed this question
 Grubhead
Grubhead
