Question about Microwave Ovens
I have a mr coffee thermal carafe coffee maker with a clean cycle button. can i use vinegar in it to clean?
    Brigadier General:
  • 8,909 Answers
Spirit vinegar is not only perfect for the job of descaling but environmentaly friendly.
Posted on Jan 01, 2011
We have a Mr Coffee 10 cup thermal programmable coffee maker COF FTTX95-1 The clean light is blinking and I can't figure out what else to do. HELP!
When the clean light is blinking it is saying that the tubes are blocked up with mineral deposits. If you waited until the light in blinking then it is going to take some time for a vinegar clean to work.
Just put vinegar where you normally put the water, and let it perk about 1/3 of the water through, and then shut it off for 30 minutes. Then restart and let it perk another 1/3 through. Let set for 30 minutes. Then let it complete the cycle.
Take a look at the output vinegar, if there is a lot of chunks in it, strain it using a coffee filter and then reuse the same vinegar and do it again. Keep repeating until the light is out and the vinegar no longer get the chunks.
Jul 13, 2011 | Microwave Ovens
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
I need 48oz of undiluted white vinegar to clean my coffee maker. where can I buy it in Glendale Az, area.
You can buy vinegar wherever you buy your groceries and most convenience stores..
Feb 23, 2011 | Microwave Ovens
How do you clean a Mr Coffee Model Number COF JWX27?
Most folks run white vinegar through one cycle to clean a coffee pot ... follow by one regular water cycle (no coffee).
Feb 09, 2011 | Microwave Ovens
How do you clean a Tim Hortons home coffee maker. This model has the heated water reservoir with a pot of hot water always ready
UNPLUG IT FIRST, SAFTY FIRST
LET IT COOL OFF,
EMPTY THE WATER AS MUCH AS POSSIBLE
THEN CLEAN WITH 409, OR MR CLEAN, OR WINDEX WITH
A LITTLE BIT OF VINEGAR ADDED ( ABOUT 3 ~ 4 TABLESPOONS )
TO HELP IN CUTTING THE GREASE
THEN BEFORE YOU PLUG IT IN, ADD SOME WATER TO THE TANK,
PLUG IT IN, RESET YOUR CLOCK { IF YOURS HAS A CLOCK }
AND ENJOY !! dd
Feb 05, 2011 | Microwave Ovens
We received a 14 Cup Delonghi coffee maker DC312T and the carafe leaks. We love the coffee maker, & do not wish to return the unit. It was ordered on-line... All we need is a replacement carafe. ...
Sorry to read about your problem, I hope this helps you out.
Contact Delonghi at Delonghi.com
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | DeLonghi Microwave Ovens
I am in need of replacemnt carafe for a Kenmore Wave and Brew microwave/coffee maker seriel #721.63993301
HI. I have located the parts needed. I will place two links for the cover and the actual Carafe, as well, below:
Carafe Cover - 3550W1A231B
Carafe - 383EW5A162C
Please rate and have a great day:)
Aug 19, 2010 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Microwave Ovens Logo
121 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
