Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
PD170 Record Button Won't Work
My PD170 won't record. I've switched tapes, re-powered multiple times - nothing. None of the record buttons work. Any thoughts?
  • 1 more comment
  • deconoel Nov 10, 2008
    I also have a similar problem, boton doesnt work and a error message is on the screen C30:31 and the eject symbol is also on the screen.
    I already try whit diferents tapes
    I supose that the camera doesnt recognize the tapes or is somethig mechanical.
    Can someone help me? I live in spain
  • Jean Sintulaire May 11, 2010
    Without taking the camera apart, it will be difficult to say with any confidence. Have you looked around to see what a repair estimate will cost? Perhaps you can get a detailed estimate from a local shop. We may be able to walk you through the repair?
  • dsr_specialist May 05, 2012
    You must change the swicth block assy
  • 29 Answers
Any one of the record button will be struck or short...
Posted on Jan 07, 2010
    dear deconoel...here the solution..
    you must use remote commander here the step to check :
    1. page 0 address 01 data 01
    2. page d address 10 data 02 for entering mechanical system
    3. page 3 adress 01 data 0b for testing mechanical without cassete
    4. see is it can loading motor work? if not there a problem with the capstan assy
    5. replace the new capstan, and it will work
    please send me email if your problem doesnt solve trough dsr_specialst@yahoo.com
At digital change over , will my dvd/tape recorder still work. type DF-4100p
It will still play DVDs and videos, and record from one to the other, but you won't be able to record from TV onto either format now. (I know: I've got one!)
Sep 04, 2011 | Daewoo Televison & Video
My computer won't turn on, it just has a blinking dash on the left hand side I've tried turning it off and on multiple times and nothing will work I have an assigment due at the end of this week...
while the computer is turning on push the escape key and try selecting the harddrive
if it doesn't start to boot into windows then your boot record is probably corrupt you can try fixing it by running chkdsk /r on your OEM reinstall disc that came with the computer, seeing as you have a netbook you will need a external cd rom
Jun 14, 2011 | ASUS Netbook
Record button does not work I press the record button and ejects the tape
The sensor switch which pushes against the record tab on the tape is either bent out of shape, or broken. Therefore the video recorder thinks that the tape you put in is a pre-recorded or protected tape, thus ejects it.
Dec 21, 2009 | Emerson Televison & Video
Handycam CCD TR517 Doesn't record
These models have a switch for 3 different modes of record. one where you press the red button once, one for having to hold the red button in and a 5 second record feature, check this mode. also check and make sure the tape you are using did not have the record save switch slid into record save position..
Jul 20, 2009 | Sony Handycam CCD-TR517 Camcorder
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Wont record or playback tapes
There you go. Thats a good way to get the problem solved.
Aug 08, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Red power light flashes twice and unit will not record. I will not play a tape, none of the tape keys work (rewind, fordward, or pause, etc). I do get a picture in both the vcr and camera mode but the tape...
1. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS AND CREDIT TO LABBER
Dec 20, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Time code breaks
have the PD170 professionally cleaned; a worn pinch roller causes time code inaccuracies like the ones you are describing.
Nov 12, 2007 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
172 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
