Question about Bosch WET 2820 Front Load Washer / Dryer
Bosch wet2820 banging when going into spin - Bosch WET 2820 Front Load Washer / Dryer
Drum will not spin correctly
Sounds like the drum bearing is worn out or the rollers that support the drum are worn out.
Feb 13, 2014 | Bosch Neff Beko Dryer 263297
RE. Bosch Nexxt 100 series. Does not spin. I have cleaned all hoses, outflow and inflow. Opened the little circle door at bottom right and it is clear. The fan even spins during drain cycle. I do hear...
Check connectors on motor assembly they can become loose due to the high speed and vibration. Motor and drum are tied together. I had similiar problem with mine after spending a few hundred on a control board which made no difference.
Oct 12, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Bosch WET2820 washer/dryer and if I am away from home for a week, water starts to assemble in the interior of the machine and the moisture starts to smell badly. I select the drain programme, but...
the water inlet valve is letting the water by, you will need to fit a new one. to get the correct part number you will need the model number which u already have and the "FD" number to get the specific model as there are a couple of varients. you should find the fd number on the silver rating plate inside the door
Nov 19, 2010 | Bosch WET 2820 Front Load Washer / Dryer
Hello, I need a manual for a washer/dryer - bosch wet2820. Thank you.
you'll get it on the net but you'll need to pay for it that's why i didn't got it sorry
Aug 26, 2010 | Washing Machines
Water not draining although spin still ok. Then went bang!
Called out a plumber who diagnosed that the machine was not worth mending. He charged me £25. Now have new Indesit WM.
May 23, 2009 | Bosch Washing Machines
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WET2820 integrated washing machine. Cycle gets stuck on "anti-crease 1". Have followed instructions in manual for unblocking drain pipe, hose and suds pump although problem (doesn't drain...
was a hair clip stuck in the drain pump..
fixed like this:
Use the small draining pipe that is fitted to the filter housing to drain the water down.
Take the filter out from front bottom.
Inspect and remove any debris blocking the drain pump.
et voila! working!
Jul 10, 2008 | Bosch Washing Machines
WET 2820 programs
I have noticed on bosch website that WFT2806 is exactly the same model and there is a manual to download.
go to http://www.bshappliancecare.com/Bosch/ and select instruction manuals then search for WFT and wait, the page will authomatically redirect you to the manuals for WFT2806GB which I think is the free standing version of the washer.
enjoy.
Jan 04, 2008 | Bosch WET 2820 Front Load Washer / Dryer
Open Questions:
See all Bosch WET 2820 Front Load Washer / Dryer Questions
Bosch WET 2820 Front Load Washer / Dryer Logo
26 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
