Question about Toshiba Regza 46RV535U 46 in. LCD HDTV
I have the same problem with a Toshiba RGZA 46RV535U purchased 2/2009. My picture gets darker in the center 1/3rd of the screen intermittently. I have removed and reconnected all cable connections on the main assembly pc boards including the C board connections. I have not disassembled the display panel at this point. My question is concerning the LCD Backlighting. If the backlight tubes are placed vertical then it could be an inverter board problem. The area is too wide to be a single tube. That puts in somewhere in the area of inverter board and connections. If they are located horizontally I am back to square 1. A web search indicates that the tubes are available for purchase but does not provide the specs. This would allow me to determine tube placement. Does any one know if the tubes are vertical or horizontal?
The tubes are horizontal but require disassembling the cover and the inverter
board completelyfrom the chassis. There were 17 of these flourescent tubes stretching the ful length horizontally. They are so fragile.
Posted on Aug 24, 2012
3 Suggested Answers
  • 66 Answers
SOURCE: Westinghouse LCD tv LTV-32W4 has great sound but no picture.
Your television actually has a backlight bulb which can be replaced at our parts request email and phone number. Email address: Parts@wde.com. (866) 839-5888
Posted on Jul 29, 2009
  • 8457 Answers
SOURCE: How do I determine which backlight inverter is
Most of the time is the Master one.The A board,But sometime the Slave board B.Take chances,but the A is the best chances,because is the Master board.
Posted on Feb 08, 2010
Testimonial: "Then I will go for the A thanks."
Toshiba 47L622U will only get start-up screen "Toshiba" will not go to signal (tv picture) what could cause this? started as intermittent problem
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 07, 2017 | Toshiba Televison & Video
Why is the picture too dark and getting darker
This happens on LCD (not LED) flat panel screen, the fluorescent tube gets ageing.
Sep 12, 2014 | Toshiba Televison & Video
Does Samsung tcon board fit Toshiba TV?
maybe we are smart enough to know better than to be inpolite.
Dec 05, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
No picture or sound
The 42RV530U is known to develop problems in both the power board and the main board. You can check out a power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and you can also search for 42RV530U at http://blog.coppelltvrepair.com.
Hope this helps.
Jan 04, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Toshiba 27A45 picture and colors began to get darker and darker until whole screen is black. Sound still good. After a minute or two the picture returns fast.
Sounds like horizonal output transistor could be over heating. There could be other problems. But I would start there. You can find the part number on the schematic inside the set. If you change it yourself don't forget to use the included insulater. Part should cost between 15 & 20 dollars. You will need make & model # of set at electronic parts store.
Diagrahm inside set will show you location of transistor
Jun 07, 2011 | Toshiba 27A45 27" TV
The picture seems to be getting darker. Its not as bright and sharp as it used to be. Its about 9 years old but has not been used very much. Might it need a new bulb or something? 57HX81 Proj TV Color...
simple: remove back cover and locate the three large black lens you will see top and dead center, clean them with either a lens cloth or a paper towel with glass cleaner----they are the light source for your picture and should be cleaned once a year---as they get dusty the picture gets darker and duller looking.\\
SD TECH
Apr 12, 2011 | Toshiba 57H81 57" Rear Projection...
Toshiba 46 HD TV-1/2 Screen going out
I have a Regza 46XV648U. And sometime my sound will sound like a Echo Chamber, i can turn it off and the sound will be alright for some time.
Aug 02, 2010 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Why is my toshiba 46h84 picture getting darker than before? Its becoming harder to see darker scenes in movies
It sounds like your lamp is getting close to the end of its lifespan.The lamp is what gives your screen its brightness.With time they start losing this brightness.If you were to wait to replace it till it goes out completely you would have a black screen.You can purchase a quality lamp at discount-merchant.com
Apr 16, 2010 | Toshiba 46H84 46" Rear Projection...
Toshiba 46RV5354 replacement lcd screen
Best of luck finding a replacement screen. Typically the screen is what get damaged and finding an exact model with some other issue is your only hope, that and finding someone to ship it to you as in most cases it's only local pickup. I think you'll find a replacement lcd (new) cost is way more than buying a new set. Best of luck.
Jan 02, 2010 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Toshiba Regza 46RV535U 46 in. LCD HDTV Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
