Question about Kenmore 53642 / 53644 Side by Side Refrigerator
REFRIGERATOR ON BLEAK
AFTER APPROXIMATELY EVERY TWLEVE HOURS, THE REFRIGERATOR, FREEZER, STOPS WORKING AND WATER STOPS DISPENSING, THEN COMES ON AGAIN AFTER ABOUT THE SAME TIME.
  • 481 Answers
Sounds like a problem with the defrost timer / control board. the defrost timer cycles into defrost every 12 hours and turns off the compressor and fans. it seems like it is malfunctioning and causing problems with other components too.
Posted on Jul 08, 2008
There is no water coming from door water dispenser
I don't have a GE side by side, I have a Cafe bottom freezer. Water dispenses from the inside. Occasionally, the water has stopped working. Each time I've replaced the water filter, and that has solved the problem, not immediately, but after a few hours to a day. That's the best suggestion I can come up with, but remember ours is a similar, but not identical, refrigerator.
Jun 10, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Electrolux 23 cu ft refrigerator (EW23CS65GS1) Water dispenser problem. The water dispenser on the freezer door does not dispense water but the ice dispenser is working fine. I turned off my refrigerator...
the line is freezing up if you pull the bottom drawer out of ref side you will see a rolled up plastic line they use it as a resovoir tank so you get cold water if you have a vent in bottom left side close it i have put insulation over coil that fixed problem and turn down thermostat if milk and other stuff is freezing you will have to replace cold control
Oct 17, 2011 | KitchenAid 20.3 cu.ft. Counter-Depth...
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser keeps freezing GE Refrigerator
If this is a newer model GE side by side refrigerator, this is not uncommon. what you can do to check to see what is going wrong, remove the toe plate at the bottom front of the unit. Under the freezer door, you will see a white plastic water line, with an inline connector about 4-5" from where the line comes out the bottom of the door. this is normally a blue push-in type connector. On this connector, you will see two white sleeves on either side, push in on this sleeve while pulling the corresponding water line section out of the connector, if you squeeze the sleeve enough, the water line will slip right out. Place a towel on the floor, make sure both ends are on top of towel. Now, breifly actuate your water dispenser trigger, see if water comes out the exposed water line. If water comes out, your entire water dispenser system is OK, but, the water line in the freezer door is frozen, in which case the only way to melt it, is to turn the unit off, open the freezer door, and blow a fan for a few hours, to melt the ice INSIDE the door. You could also buy a new door, but that is very costly.
If no water comes out the exposed water line, then either your water filter is clogged, or you have a bad water valve solenoid
Feb 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
No water from water dispenser
I have a GE GSH22JFTA side by side and my water dispenser just stopped working after about a year. The selenoid for the pump is buzzing, and when I disconenct the water line at the bottom on the freezer door, it water dispenses fine. the water is freezing IN the freezer door. I got some plastic sheathing and duct tape and opened my freezer door and sealed the freezer compartment so the food would not defrost and left door open to thaw out. in about 2 hours, voila.. my dispenser was working again. I suspect I'm not the only one with this issue.
Mar 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
No water
I was having the same problem.  I was told that the water line in the door is frozen.  I was told to open up the door and take everything off door and put towels in front and around the ice maker and the rest of the freezer to keep the cold in and  leave my door open and tape the light switch so it would turn off.  Then keep the door open, for 1-2 hours, I checked it in 1 and it still did not work so I continued for another and it now works just fine.  My ice maker was working but the water was not coming out of the dispenser.
Nov 14, 2008 | Hotpoint HSS25GFP Side by Side...
Water Dispenser with mind of it's own
one test is too turn off your ice maker and it will stop...you have a bad diode on the water line and are getting line feed from the ice maker...
to fix it you will need a new diode
#5303918287 DIODE KIT
#5304418384 DIODE KIT
the parts store will get you the correct one with a model and serial number of the refrigerator
let me know if it helps
Nov 03, 2008 | Frigidaire Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
