Question about Amana ARB2217CSL Bottom Freezer Refrigerator
Back wall frosting up - Amana ARB2217CSL Bottom Freezer Refrigerator
  • 1,772 Answers
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice/frost on it. And you said you had frost on the back wall, you may notice the refrigerator getting warmer.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Freezer gets fool of frost on walls of freezer only
if its both sides and the top... possible causes; door not sealing all the way around, icemaker stalling and heating raising temp in freezer, or the airflow is blocked.... if it is frosting only on the back wall its a defrost issue..... more info is needed to narrow this down for you
Oct 09, 2014 | Kenmore 64802 Top Freezer Refrigerator
Frig has suddenly become warmer than usual. Freezer is at 20 degrees and frig at 60. Tried to vacuum coils but very dificult to reach them underneath the unit. Any other hints?
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up, take off the back wall of the freezer and replace the defrost heater and defrost thermostat. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead it is part of the main computer board on the back of the refrig. I would replace heater/defrost thermostat first though, since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Whirlpool GS6NBEXR Side by Side...
Freezer is cold but refrigerator side is barely cooling. turned off and water leaking out of door on the freezer side
Hello Roxanne,
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up,i would take off the back wall of the freezer and replace the deforst heater and defrost termination. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead in the fresh food compartment in the control panel where the thermostat is. I would replace heater/defrost termination first though since they are the most likely to fail parts.
Gene
Aug 05, 2011 | Maytag MZD2766GES Side by Side...
Freezer works and freezes, but refrigerator is not getting cold
hi.... look to see or you have frost on the back wall in the freezer side... you will need a new defrost element .. If NO frost on the back wall.... Is your fun running??
Mar 31, 2011 | GE Refrigerators
Maytag mzd2666geq refrigerator does not freeze - both freezer and refrigerator - it started yesterday afternoon. There is a lot of ****-frost on the freezer back wall. Evaporator motor is running (I...
REMOVE THAT FROST WITH A HAIR DRIER. THIS SHOULD MAKE IT WORK FOR UP TO 21 DAYS. THERE IS A 95 PERCENT CHANCE THE ADAPTIVE DEFROST CONTOL IN THE CEILING OF THE FRESH FOOD SECTION HAS FAILED. YOU CAN ORDER THE PART AT...
http://www.searspartsdirect.com/partsdirect/index.action
Apr 23, 2010 | Maytag MZD2766GES Side by Side...
HELP ME
Remove back wall from inside freezer and melt all frost with a hair blower. The most likely cause of the frost build up is a burnt out defost heater, second most likely cause is the defrost control. Can't give you part numbers because you don't list a model number or even a brand. Melting the frost and not fixing the underlying problem will get your refrig working for a week or so until the frost builds up again.
Jul 03, 2009 | Refrigerators
The fridge section of my LG GRB218JUDA has stopped working and the temperature indicator reads Err FF. Can you help
Side by side and other refrigerators are controlled or cooled by one system. Look to the freezer side for frost buildup on the back wall of the freezer. Frost buildup on the back wall of the freezer stops the air that cools the refrigerator from circulating. Frost on the back wall indicates a problem in the defrost circuit related to the timing device, heaters or defrost thermostat.
Jun 02, 2008 | LG Refrigerators
GSH25JFTCC
Check for frost on the freezer back wall. A frozen coil will cause both problems. If you see frost on the back wall you have a defrost system problem.
Apr 09, 2008 | Hotpoint HSS25GFP Side by Side...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ARB2217CSL Bottom Freezer Refrigerator Logo
118 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
