Question about Sony DCR-IP7BT Camcorders
My sony dcr sr 35now only shows a white picture ,.does this mean i ve lost all the film on the hard drive?i ve checked the nightshot its on off.
  • 1 more comment
  • maurice_fisc Jan 02, 2011
    hello, thank tou for your prompt reply. to answer your query ,all i get is a white blank screen.
    hello is the wire easy to repair myself or is it better that i get it repaired by a pro.i don t know anything about camcorders.
  • maurice_fisc Jan 03, 2011
    yes thank you
  • 10,594 Answers
Do you get Touch buttons working on lcd screen?
No, you have not lost previously recorded movie files, they are saved in hard disk.
Let me know bit details about live view in lcd in camera mode to troubleshoot.
Thanks.
Posted on Jan 01, 2011
  • Shahid Electronics
    Shahid Electronics Jan 02, 2011
    OK, it seems flexible connecting ribbon wire between lcd and camcorder is cut/ broken. Camcorder will take apart for visual check of that flexible ribbon wire.
    I can provide you part number if required.
    Thanks.
    As you said you do not know about camcorder repair then it is recommended to get help of local camera repair shop to avoid further damage.
    They will replace flexible ribbon wire properly.
    Thanks.
How can i change the interface language of my Sony Handycam DCR TRV9 nightshot- camcorder - Mini DV.its japaneese and i want to change it to english
My research shows that model is only for sale only in Asia, I looked into some similar USA released models and they did NOT have multiple language support so I am thinking that the DCR-TRV9 is only in Japanese.
Just out of curiosity are the markings on the camera body in English or in Japanese?
Dec 03, 2010 | Sony Handycam DCR-TRV9 Mini DV Digital...
Negative picture when filming
I found the home website for your camera on sony.com's european website:
http://support.sony-europe.com/dime/camcorders/sd/d8/d8.aspx?site=odw_en_GB&m=DCR-TRV140E
I didn't see anything about a negative picture on screen when filming, though.
Good luck on finding a solution to your problem.
Jul 18, 2010 | Sony Handycam DCR-TRV140E Digital...
Can't turn off nightshot on my handycam help!!!
Option 1:
Using the NightShot:
1. First Set the POWER Switch to Camera, Slide NIGHTSHOT to ON.
2. The NIGHTSHOT indicators flash on the screen.
3. To cancel the NightShot mode, Slide NIGHTSHOT to OFF.
Option 2:
1. Let us try to reset the Camcorder and check if it helps to resolve the issue.
2. Locate the RESET button behind the LCD screen of the Camcorder.
3. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Accidently turned on nightshot,can't turn it off
  1. Open this link to the user manual.
  2. http://pdf.crse.com/manuals/2661364112.pdf
  3. Go to page 42 of the manual. The picture shows switch #1, which is on the top of the camera. Move this to OFF. This will remove the Nightshot.
Mar 20, 2009 | Sony Handycam DCR-DVD805 DVD Camcorder
Can not set the camcorder to Super Nightshot Plus mode
To enable " Super Night Shot " option, find slide switch at top of camera as shown in picture...Regards,
Aug 21, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony DCR-HC51
This is the solution, I would only add that it's on the top of the camera itself. Not in the digital menu or backlight button. On my older version, it's between the cassette and lens sections of the camera.
Never having used the nightshot before, my sister left me with the same quandary...
Jun 29, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony handycam camcorder lcd screen white and no displays
For the "all white screen" in daylight problem, check to make sure the "Nightshot Plus" slider switch is set on "off."
Jan 05, 2008 | Video Cameras
Turning off nightshot
Maybe your blacklight is on. Hope that helps.
Mar 15, 2007 | Sony Handycam DCR-DVD505E DVD Camcorder
Sony DCR-IP7BT Camcorders Logo
69 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
