Question about Dacor PCOR30 Convection/Microwave Oven
The microwave stops after 50-60 seconds regardless of the amount of time left on the panel
  • Dacor Master
  • 9,047 Answers
The PCOR30 microwaves are essentially a rebranded Sharp R-1870-series ovens.
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
The service manuals that cover these models are here:
http://www.microwavedisplay.com/r1874_sm.pdf
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
http://www.microwavedisplay.com/r1850_r1851_sm.pdf
The above manuals will not have Sharp part numbers, not the Dacor part numbers, but they should work, and you can order them from
the Sears Parts DirectThe microwave stops after 50-60 seconds regardless - image-4235112-10659157 site.
But if you're leery or unsure, you can look up the Dacor part numbers in the part list here, then order by part number from the Pros here.
Posted on Jan 02, 2011
I have a Panasonic Microwave the Genius Prestige and when I set the time to cook it turns off in 9 seconds even though I set it for 50 seconds. what should I do?
You have a defective timer circuit board, which I assume is part of the main board of the microwave. If the unit is older just replace it, if it is relatively new call a Panasonic repair service and get an estimate to repair it, I think you will be shocked by the cost to repair.
Jul 18, 2016 | Panasonic Microwave Ovens
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
Mar 24, 2016 | Sharp R-1870 Convection/Microwave Oven
We have a 3 year old Cooke and Lewis integrated microwave/grill that has recently stopped working. It starts up but after 5/6 seconds it stops and 'err 5'comes up on the display. Any ideas?
if this was purchased from the likes of B&Q, at the time of purchase, the retailer must ensure that the goods are/were fit for purpose for a period of 6 years from date of purchase. This is regardless of manufactures warranty. Take it back, demand a new one, quoting the above
Jan 02, 2016 | Microwave Ovens
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
Time
follow the next steps use the VOM and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Jun 18, 2013 | Panasonic NN-S254BF Microwave Oven
Set clock but time goes off
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 02, 2012 | Viking VMOS200 Microwave Oven
Mi panasonic prestige inverter microwave will not
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Jul 18, 2010 | Panasonic NN-P295SF Microwave Oven
Timer shuts off
there was a similar problem posted on your site that solved my problem.
Aug 18, 2009 | Sharp R-1870 Convection/Microwave Oven
MW8119SB cooks when door is closed regardless of settings
Clear the cook cycle when you remove the food. Some microwaves pick up where they left off, so you don't have to keep pressing buttons.
Aug 07, 2009 | Emerson MW8778 Microwave Oven
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
Dacor PCOR30 Convection/Microwave Oven Logo
296 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
