Question about Whirlpool Washing Machines
Model 650H: Getting error code "FE" What is this and how to correct it?
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: My LG Dishwasher model LDF7811WW was getting
Hi
Thanks for using FixYa. Error FE in your Dishwasher indicates excessive water is supplied than the normal water level. If the dishwasher is overfilling it's
caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 28, 2010
Why would a Samsung gas dryer, model DV400GWHDWR-AA cutout and show a FE code after about three seconds after pressing the start button?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
Sep 26, 2016 | Samsung Dryers
Getting FE error saw a answer for this model on fixya said to clean the float module where no plastic float on bottom of washer
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced. If the error persists even after the water inlet valve has been replaced there may be a problem with the main control circuit board
Oct 25, 2015 | LG LDS5540 Semi-Integrated Dishwasher with...
Front load kenmore elite washer show code FE why
The FE code is probably an overflow error. The intake valve is stuck in the open position and the washer can't advance to the next part of the cycle with the water coming in. You need to replace the inlet valve.
Since you didn't provide the full model number, I can't point to the correct replacement part for you. Please post a comment with the washer model for additional information. If your washer is still under warranty, contact Sears for service. ( searspartsdirect.com will likely have the parts diagram and sell the correct part. However, other vendors may have the valve at a better price. This will depend on the model.)
I hope this helps.
Apr 03, 2015 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Samsung washing machine
Based on my experience, the same thing happens to me as you have mentioned that it happens every end of a cycle. I doubt if it was a fan error or a frequency error. for me, its just a simple overload for the autodrying. for example on my model. the manual says autodrying cotton-cupboard dry must be max 3 kg. since you cannot measure your wet clothes and it sometimes exceed the 3kg autodrying, that is when the FE comes out. but when i remove some clothes or spin the laundry again and put it into drying, everything works fine. when i use the machine with minimal clothes say 2kg dry, the whole cycle up to drying work fine without FE errors.
So i believe its just an error for drying overload. also the manual says nothing about FE nor Error code for drying overload.
Hope this help.
May 31, 2012 | Washing Machines
I have a Maytag Neptune electric dryer model # MDE9700AYW and I have a fault code " FE " & the dyer doesn't dry the clothes. What is my problem
Maytag Dryer and FE code means power source "Frequency Error".
Invalid power... you will need a electrican to come out the power is not wired up right.
I would replace the wall receptacle before buying any dryer parts
Hope this helps (remember to rate and comment this answer).
Jul 01, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
I am looking for a replacement bulb for a Kodak carousel projector model # 650H where can I find one
The 650H uses a 300 watt, 120 volt lamp with an ANSI code of "ELH". You can order "ELH" lamps from Bulbman (www.bulbman.com).
Aug 08, 2010 | Kodak Office Equipment & Supplies
Getting a E1 code one the front panel and will not finish the cycle
There is not a reference for an E1 error code.
The listed LG error codes are:
IE, UE, OE, FE, PE, dE, tE, LE, EE, and PF.
May 18, 2010 | LG WM2016C
Washing Machines Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
