Question about NAD T753 Receiver
I have an NAD T743 reciever with error codes U201/U202 showing. After a while display became empty, reiciever is not respond to remote controller or the front buttons. But after this I can listen anything what I want because the on the last used input is "working". I only cannot modify anything with the settings. (I only can swith off on the back) Please help! Many thanks for your support! Viktor
SOURCE: OVER HEAT
To reset the the T743 hold down the video 6 and the source up buttons for 3 seconds. then power up from the back button
Posted on Sep 13, 2008
SOURCE: Does not respond to remote control
I have had the T743 for about three years now. The first unit which I got from the local shop was doing exactily like your described after couple of minutes use. Well, I took is back and got a new one covered by the warranty.
Unfortunately I never got any explanation to this problem from my local shop or anywhere else, so I guess the only way is to contact your local shop.
Posted on Dec 30, 2007
SOURCE: Power on T743
Just had my t753 in bits... sounds like its overheating to me. Check that the fans on the bottom still turn and aren't clogged up with dust. Make sure that it has plenty of ventilation.
hmm, also try unplugging everything and leaving it on and see if it still freezes? ie check you're cabling is ok, there are no shorts from bare speaker wires etc...
Could try resetting it too? (in each case hold the buttons for 5 seconds then release)
- Firmware version: hold video 6 and tone control
- Reset DSP: video6 + tone defeat
- Reset completely: video6 + right source button (this will wipe all settings - hold for 5 seconds, release and then unplug from the wall or turn off with the rear power switch)
Posted on Nov 30, 2008
SOURCE: NAD T743: The digital channels stop working after a short time.
I had the same problem just once, about a week and a half ago. Don't tell me that this problem is going to get worse.
Posted on Feb 04, 2010
SOURCE: My NAD T743 will not switch on
Hi, have you checked the power button in the back to see if it got pressed by accident? It's a round button located right under the speaker inputs in the back.
Posted on May 09, 2010
How to reset a NAD L54 DVD reciever?
This is the technical solution, you have to open the unit:
Locate IC33 and connect pin 6 to ground, connect power, and then remove the ground connection at pin 6.
The unit will then boot up in factory default.
Henrik Pedersen
Jul 20, 2012 | NAD Audio Players & Recorders
The amplifier has occasionally shut itself off due to overheating for the last 3 years (I've had it since 2005). But now it continuously shuts itself off and simly won' start up anymore. Does it need a...
They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
A heat sink is just a finned heat-conducting device for radiating heat to the air which should be flowing freely through the unit's ventilation holes. It can't break in normal use. But it CAN get clogged with dust reducing its effectiveness.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T743-Receivers-manual/id/8043bh636/t/2/
Page 6
"Choose a location that is well ventilated (with at least several inches to both sides and behind), and that will provide a clear line of sight, within 25 feet/8 meters, between the receiver's front panel and your primary listening/viewing position-this will ensure reliable infrared remote control communications. The T 743 generates a modest amount of heat, but nothing that should trouble adjacent components. It is perfectly possible to stack the T 743 atop other components, but the reverse usually should be avoided. Nonetheless, it is generally preferable that the T 743 stand alone. It is especially important that sufficient ventilation be provided; if you are contemplating locating the T 743 within a cabinet or other furniture, consult your NAD audio/video specialist for advice on providing adequate airflow."
If you're lucky, you haven't finally toasted it. If you have, a hands on tech will need to sniff sround (literally) to find the dead component(s).
Mar 06, 2011 | NAD T743 Receiver
My NAD T743 will not switch on. I haven't used for a couple of months and it was working just fine before. Now I tried switching it on using both the power button on the amp itself and the remote, to no...
Apr 11, 2010 | NAD T743 Receiver
Nad 743 shuts off at -14db vol. Why?
mine got fixed by replacing the front panel PCB with control processor. Only 350€...
Feb 28, 2009 | NAD T743 Receiver
NAD T760 remote control
You could buy a universal remote control and try the following NAD audio remote codes to program it with:
NAD
575 773 975
I read somewhere else that the 'Supplied Code for NAD receivers' was 033, but cannot confirm this. Try the first 3 first.
Universal remotes tend to be pretty cheap, certainly cheaper than buying one from NAD.
Good Luck
Chris (ziraffa)
Dec 20, 2008 | NAD T760
Using NAD t743 with Panasonic DMP-BD55
The reciever you have has 5.1 inputs at the backof it.The only way to get Dolby True HD and DTS HD is to run the 7.1 analog out from the bd55 to the nad. You'll have to leave the 2 rear surround open on the bd55 leaving the remaining 6 connected to the nad. The digital coax and the optical will not transmit the hd data, only the analog out will. Run a hdmi right to your HD tv for picture bypassing your amp. this will workfine and you'll have the audio you want. You,ll have to change the input settings for dvd in your amp to 5.1 to recieve the audio.
Dec 14, 2008 | NAD T743 Receiver
Power on T743
Nov 23, 2008 | NAD T743 Receiver
OVER HEAT
Aug 18, 2008 | NAD T743 Receiver
Turns itself off
NAD Technical Bulletin T743-H2005-06 describes the problem "Unit may shut down, shortly after turn on".  Reason: There is a diode on the standby board that maybe operating intermittently.  Solution: Locate and identify D756 on the standby board.  Change only if the diode is a 1N4148.  Change from a 1N4148 to a 1N4004 or equivalent.
It is located near a transformer and some fuses.
Aug 07, 2008 | NAD T743 Receiver
Dec 27, 2007 | NAD T743 Receiver
NAD T753 Receiver Logo
224 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
