Do not know how to progran regency r1070 scanner. ihave freq. iwant need to know hoiw to program tommywhiggum@yahoo.com
voodoomox
  • 1689 Answers
SOURCE: programming
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
http://www.w7fg.com/index.html
for scanner and old radio manuals.
from WikiAnswers
good luck
-voodoomox
Posted on Jul 26, 2008
  • 11 Answers
SOURCE: Regency R1070 scanner Fr Err
if an out of band frequency is put in that channel you will get the Fr Err message as well, just put in a frequency within the scanners specs
Posted on Apr 20, 2009
  • 56 Answers
SOURCE: I need the special programming proceedure to
First you need to be running DOS to do this. Next when you load the software press and hold shift when you use the numbers for the freq's.
Posted on Jul 22, 2009
SOURCE: I dont no how to program my regency z30 scanner
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you wish to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Posted on Sep 28, 2009
SOURCE: regency scanner r1070 error message fr err, will not scan
I'm assuming you know already, but just in case you don't. You need to be scanning in supported ranges, those are:
30-50 Mhz
144-174
440-512
Posted on Nov 03, 2009
Where can I buy an antenna for a Regency model R1070 scanner
search ebay for "regency r1070 scanner antenna" and many will pop up. Also Radio shack..
Jul 09, 2012 | Uniden Radio Communications
How do you program a Regency Programmable Scanner R1070?
Regency R1070 Frequencies for people with no manual
These are the ranges it supports.
30-50 Mhz
144-174 Mhz
440-512 Mhz
To make it scan, first set the range by pressing Manual and then Search. It will ask for the LOwer end and the UPper end of the range. Enter them, press Scan and then Search, and it will start scanning. When it locks and you want to keep going, hit Search again. You can press Delay to stop at a channel temporarily. To save a frequency in memory, hit Manual and pick a number, then type it out and hit Enter. When you have a few channels saved and you want to check up on each of them, Scan scans through memory. The Lock button is to skip a particular channel while scanning.
That's pretty much the whole manual right there.
Jan 30, 2012 | Radio Communications
This is not my product I have a Rca four band scanner (old) model # 16S400 need a manual for programming freq
The RCA 16S400 is not a programmable scanner. Rather, it's an old (70's) crystal-based scanner that requires one crystal for each frequency. It covers the VHF-low, VHF-high, and UHF bands, and utilizes Regency type crystals. You can do a Google or Yahoo search for the crystals, but eBay is probably the best, and lowest priced source.
Bill B.
Listening in since the 60's
Oct 13, 2010 | Radio Shack Pro-96 Scanner
I JUST WANT TO PROGRAN THE SCANNER CODES IN
Press program button, now channel up-down for frequency....You can get them at Radio-freq.com...enjoy....oh, you may have to flip the switch in the back....hope this helps...
Mar 05, 2010 | Uniden Bearcat Pro PC78LTW 40-Channels...
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
Regency scanner r1070 error message fr err, will not scan
i have same problem with my scanner what my prob was is moisture got into the radio and it sat for while and corosion ate one of the pins of a crystal causing it to have fr err on any channel i put it on replacing the crystal fixed it for me but with scanners anything could be wrong
Jul 18, 2009 | Radio Communications
Regency 1099 Scanner
Fr Err usually means that the freq entered into a certain channel is too high or too low for the band of the scanner. Also could mean that the freq's have been lost out of the memory. Maybe a dead memory battery, or been unhooked from the wall too long and lost it's charge. Been a loong time since I've seen one of those models,,, Let me know if it helps,,, Mechanic
Nov 04, 2008 | Radio Communications
Acer AcerScan 620P Flatbed Scanner Porblem...
I have a AcerScan Prisa 620p but have no driver for Windoes XP
Mar 03, 2008 | AcerScan 620P Flatbed Scanner
UNIDEN BEARCAT BCT 15
go to menu -hit yes look for new channel and add freq email me a ghe518@yahoo.com
Jan 17, 2008 | Office Equipment & Supplies
Programming
Try the following.
Press "Manual"
Press "Enter"
Also check out
from WikiAnswers
good luck
-voodoomox
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
jasbo
jasbo
